I need to get hold of a schematic for this as it has "died". I've had a look at the fuses and generally all else seems well on the pcb. I would to make some voltage checks to workout what has happened to our beloved unit .... Pls can anyone help? Ta Coventrysparki
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
SOURCE: I just need to find a schematic for a Denon
Does this help?
http://www.usa.denon.com/avr3300_technotes.pdf
SOURCE: avr 1801 standby flashes unit shuts off
Two resistor are open circuit(R141,R142). Replace them
