The error message also states "The trunking zone data is about to be cleared". If you select ok rather than cancel, the file will be void of any P25 trunking data.
SOURCE: Programing KPG-56D
the software is a dos executable. copy it onto your media of choice and paste it into you your other PC. vista will not run this unless you install virtual pc2007 and load win98 in the vista environment. vpc07 is tricky because you have to set up conduits for the virtual com ports that link your physical port. some serial to usb adapters won't function for these. I have had fair luck with kenwood and vertex using this setup.
This error message could be generated by any of the below reasons.
Network / Modem transmission issues
If you are attempting to open the file from a network / modem it is likely the network either is encountering collisions or other errors during the data transmission. Note: if the file is being sent through a session such as FTP or Telnet it is possible that it may not be sent properly. If the file is a text file, the file must be sent as either ASCII or TEXT mode. If, however, the file is a program or non-text file, it must be sent as a Binary file.
Removable media issues
If the file is attempting to be opened from a removable media such as a Zip disk / Floppy diskette it is possible data corruption is being encountered on the diskette itself or when coming from the removable media.
CD issues
If the file is being opened from a CD-ROM it is possible the CD is dirty or scratched causing read errors. If the CD was burned it is possible that it was burned improperly.
File is bad or program attempting to open the file is bad
Finally, if the file is being opened from the hard disk drive or other media, it is likely that the file is corrupted or the program opening the file is corrupted.
