Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
If you are trying to figure out how to insulate your windows by installing cellular shades, I'd recommend you take a look at the following guide from This Old House:
http://www.thisoldhouse.com/toh/how-to/intro/0,,536789,00.html
Solar control film (if that's what you are asking about) helps reduce heat transfer through windows. The film absorbs the UV elemnt of the sun's energy while reflecting the infra-red elements.
Have you read this article about ways to improve door and window insulation in houses? I found a lot of great ideas here:
http://www.houzz.com/ideabooks/4929532/list/Easy-Green--9-Low-Cost-Ways-to-Insulate-Windows-and-Doors
The wire bundle that goes into the front of the door for the power windows probably has a broken wire and when you open the door, it makes contact inside its insulation. You need to check all of those wire to see if any of the insulation is worn or broken. Not an easy job.
Look at this "great Stuff" product: http://www.homedepot.com/buy/building-materials/foam/great-stuff-16-oz-window-and-door-insulating-foam-sealant-248312.html#.UQpddWc5t8E
