Our fridge doesn't seem to seal properly. I have just replaced the seals and removed the door shelving from the fridge and still the problem hasn't resovled. Is it possible to remove the door and adjust the hinges? It is as though the hinges have dropped slightly and the door in now skewed. I look forward to your suggestions. [email protected]
Please check this link for tips to set this right: Door seal
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Testimonial: "which temerature censor ( there are three )"
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
SOURCE: Fridge compartment not cooling. Freezer
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: Fisher & Paykel Fridge E522B
Probably needs new fan. Most likely broken wire. Others have soldered if break easy to get to.
heatman101
