Question about Integra Audio Players & Recorders
Integra dtr 9.9 receiver - Integra Audio Players & Recorders
4 Related Answers
Anonymous
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
SOURCE: Integra dtr-6.3 receiver: Red standby light
your receiver is having a power problem. The power supply board is defective that's why the receiver won't power up. Its receiving power but it cannot transfer the current to the necessary part of the receiver because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the capacitor might not come on.
This may have occurred as a result of power surge/irregular power supply/excess power supply entering into the unit. This is usually common with receivers and electronics as a whole.
If you know about electronic repairers, I would suggest that you open the receiver and read the power board/panel with a meter, detect the bad component and replace it.
But f you don't know about electronic repairers, take the reciver to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Dec 02, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a Integra receiver
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Posted on Dec 26, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: my integra dtr 5.6 receiver
hi,
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
Posted on Jul 30, 2011
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra receiver 40.4 wont play ipod again
is it set properly for that input? does it play on the tuner setting? check the connecting cable for breaks..
Feb 02, 2014 | Integra DTR-5.1 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
I am missing the remote for an Integra DTR 5.3 receiver/amp. I have a Sony RM-AV3100 Universal Remote that I want to program to control it. Does anyone know where I can find the 4 digit remote code that...
Hello
Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
Oct 09, 2011 | Integra DTR-5.1 Receiver
Turn on receiver and turns off immediately dtr-5
I have the same problem! Could you fix it
Oct 13, 2009 | Integra DTR-5.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
193 people viewed this question
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
