It sounds like the 1222 cartridge is not compatible with your faucet. You may need to replace the cartridge with the correct one for your faucet. If you are unsure of the correct cartridge, you can contact Moen directly for assistance.
The Moen 1222 is the cartridge you want. The 1222 is the OEM number, and the cartridge carries a lifetime warranty. If you call moen at 1-800-buy-moen, they will likely send you a replacement cartridge free of charge. Some wholesale plumbing suppliers will also do it if you act like you know what you are talking about, and they don't have an aversion to "retail" customers.
I am not familiar with that cartridge, but most hardware stores and plumbing supply houses should have Moen parts. #'s 1224, 1225, 1200 and 1222 are the cartridges I'm familiar with.Bring the part with you.
It sounds like you are experiencing an issue with the installation of the Moen 1222 cartridge in your faucet. The Moen 1222 cartridge is designed to be a direct replacement for the Moen 96909 cartridge, so it should fit in the same way. If the 1222 cartridge is not going in far enough for you to reinstall the clip, there may be a problem with the cartridge or with the faucet itself.
Here are a few things you can try to troubleshoot the issue:
Make sure the cartridge is oriented correctly: The Moen 1222 cartridge has a specific orientation that it must be installed in to work properly. Make sure that the cartridge is oriented correctly and that the stem is facing the right direction.
Check for any obstructions: Make sure that there are no obstructions in the bore or in the faucet that could be preventing the cartridge from being fully seated.
Make sure the faucet is properly disassembled: If the faucet was not properly disassembled before installing the new cartridge, it may not be seated correctly. Make sure that all of the internal parts of the faucet have been removed before attempting to install the new cartridge.
If these troubleshooting steps do not resolve the issue, it may be necessary to seek the assistance of a professional plumber. It is also possible that the Moen 1222 cartridge is defective, in which case you may need to return it for a replacement.
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen: http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
If this is a Moen 1225/1200 cartridge, try this link at the Moen site for instructions. You can even click on a link at the top of that site for a step-by-step Animation Enhanced turotial that is very helpful.
how to replacemoencartridge for twohandle kitchen faucet...cartridge for twohandle kitchen faucet exporters,how to replacemoencartridge for twohandle kitchen faucet suppliers,how to replacemoencartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
