Question about Dell PowerEdge 1600SC Server
Can you run Windows 8 on Dell PowerEdge 1600SC Server
5 Related Answers
Anonymous
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
Anonymous
  • 17 Answers
SOURCE: Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Posted on Jan 11, 2009
Ekse
  • 13434 Answers
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Posted on Jun 03, 2009
graysand
wilfred graham
  • 558 Answers
SOURCE: Bad Base code image Error during boot
Does it boot to the OS?You might have a corrupted registry and you might have to reinstall the software
Posted on Sep 12, 2009
SOURCE: how to install windows7 64 bit dell poweredge
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))julyallan01_28.jpg
Posted on Dec 06, 2010
Dell poweredge 1600sc w/ ATI Mach64 w/ Windows 7 Ultimate highest video mode is 24 bit true color
Bios too old and the 32 Bit system is inadequate to manage the function desired.
Feb 06, 2013 | Dell PowerEdge 1600SC Server
How to install windows7 64 bit dell poweredge 1600sc ?
Sep 23, 2010 | Dell PowerEdge 1600SC Server
Jan 05, 2009 | Dell PowerEdge 1600SC Server
My Dell powerEdge 1600SC Server Fail.....
Sounds like you're running Windows Server 2003 and want to run a backup utility.
Fortunately, this OS ships with a built-in backup utility called we call "ntbackup."
You can launch this program from Start -> Run, or you can find it in Start -> Accessories -> System Tools -> Backup.
Jan 03, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600sc server is running
What operating system is the server using? What roles is the server doing (DNS/DHCP/DC/Exchange/etc). If it's a Windows 2003 SBS box, you're supposed to be able to run upto about 75 users. I would never run more than 30 users on an SBS box (and it'd have to be a very high spec). You may consdier bringing another server to do an aditional role (file/print) and leave the primary to be an SBS box
Oct 10, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
117 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
