Printronix T5000 Thermal Printer Logo
A
Anonymous Posted on Jan 30, 2013
109 dynamic alpha/barcode field longer than previously defined
There is one line of text that is not centered.
The phone doesnt receive text messages
it is a simple problem may be the message center number on your mobile is not defined . contact customer care and manually define the number in your message settings.
9helpful
1helpful
Is there a way to group text fields in acrobat pro so that when you type in the first field it wraps to the next field?
You create an article by defining a series of boxes around the content in the order in which you want the content read. The navigational path you define for an article is known as the article thread. You create a thread connecting the various boxes, unifying them into a continuous text flow.
  1. Choose Tools > Advanced Editing > Article Tool, or select the Article tool on the Advanced Editing toolbar. The pointer appears as a cross-hair pointer in the document window.
  2. Drag a rectangle to define the first article box. An article box appears around the enclosed text, and the pointer changes to the article pointer. Each article box you create has a label that consists of the article number and its sequence within the article. For example, the first box for the first article is labeled 1-1, the second box 1-2, and so on. The boxes for the second article in the same document are labeled 2-1, 2-2, 2-3, and so on.
  3. Go to the next part of the document you want to include in the article, and draw a rectangle around that text. Repeat until you have defined the entire article. Note: To resize or move an article box, you must first end the article.
  4. To end the article, press Enter or Return.
  5. In the Article Properties dialog box, enter the article title, subject, author, and any keywords to describe the article, and click OK.
What if i want user to only enter character in a textbox?
The field should be set as an ALPHA ONLY field! I am talking from the data base side of programming. In data bases you set a field as Alpha, Numeric, or Text. I am not sure if you will have the same options.
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Cannot find the serial key to the movie box studio instal disc
Hi yellowbret,
Sometimes the serial number is part of lager alpha/numeric character string. When tried to install and it asked you for the serial, look to see how many characters you can type into each text field. Its usually limited to amount of characters in the number. Once you have that information see if any of the numbers you can find match the total character input for the requested serial number. There is a series of numbers that are etched on the back center ring of most cd's, however, I'm not sure what they represent( I bet someone on here knows the answer to that). You may need a magnifying glass to read them. There several on-line serial key finder utilities you can explore. I hoped this helped.
Thank you for using FixYa.com
Sincerely, cyyyd7
Text Messages
have you tried to restore it to default settings?
there are some setting that has been messed up.
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
