My system works great but it is open to public and i want to add a password and dont know how
You need to set WAP or WPA2 encryption to prevent public access.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
SOURCE: We have a WRT54G2 Linksys Router - which number is
This pin number is written ad the bottom of the router
SOURCE: Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
SOURCE: i can't configure my linksys wrt54g2 v1
open a browser. type in 192.168.1.1 user name should be admin p/w admin if not, there should be a small hole in case, called reset. press this in while plugged in for 10 sec. then start again. once you are in you will find all the options. you may wish to refer to their website first.
SOURCE: how to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
