Question about Apple iPhone Smartphone
Everything on my iphone works but I can't see anything the view is black
I dropped my phone in 1/2" of coffee :( grrrr The screen is black but everything works, I just can't see anything.
Posted by mspeidel60 on
cprtcenter
    New Friend:
  • 21 Answers
This iphone repair is rated " HARD "
Your phone is water damage and there might be multiple issues. If you can, just open the iphone and try to clean LCD connector. It seems like there is short on LCD connector and it is causing issue. If you clean it with contact cleaner your phone will work 100% fine.
if that does not work then you for sure need iphone screen replacement you can do it yourself or the best is to take to cell phone repair store and get it fixed.
Posted on Feb 01, 2013
5 Related Answers
Anonymous
  • 70 Answers
SOURCE: Dropped iphone with WHITE Screen
Hi
There might be a Flex cable that disconnected in the phone, you will need to bring it to a cell phone shop or apple to have a look at it.
David
CellUnlock.net
Posted on Feb 25, 2009
Anonymous
SOURCE: Iphone display doesn't work after it dropped
Check for broken LCD inside your iPhone. Other thing it might be loose connection between LCD and its socket. Here is disassembly guide for your iPhone
www.youtube.com/watch?v=8fF0DF-mbn4
Posted on May 20, 2009
Anonymous
  • 50 Answers
You have broken the Liquid Crystal Display (LCD) the touch screen digitizer and front glass is a seperate unit so that is why it still works. The LCD is the visual part and can be purchased online and fitted yourself if you feel up to it and is not that expensive, Videos of how to do it also on youtube. Or you can take it to a mobile repair centre to get them to do it for you.
Posted on May 29, 2009
stwill2326
Steve Williams
  • 77 Answers
You will need to take this phone to Apple. Hopefully you have a warranty. I had the same problem once on my Iphone...It cost me 199 to replace my phone.. i had no insurance. You screen is damaged.Sorry.
Caleb S
  • 37 Answers
SOURCE: my iphone A1303 when i tap phone button keypad is not coming. instead of that screen displays "Clear all recents" in red color & cancel . How do i get keypad. Pls suggest
The best option is to hold down the lock button until the phone turns off and then turning the phone on again.
Posted on Nov 29, 2012
tip
How to Hard Reset an iPhone
<p>Owners and users of the Apple iPhone generally report loving the phone, but they also report frequent lock-ups where the screen suddenly freezes or goes black altogether. Some report success solving the problem with a soft reset or the holding down of the sleep/wake and home buttons for the 10 second reset requirement. If this does not work, a hard reset is required to bring the iPhone back to life.<br /> <br /> <span>Instructions</span> <ol> <li> Update iTunes to version 7.4 or higher from the Apple website if you haven't already. <li> Connect the iPhone to your PC. You are automatically taken to the sync management page, and iTunes automatically begins syncing, or copying/backing-up the calendars, <a href="http://www.ehow.com/internet/">Internet</a> bookmarks, contacts and e-mail accounts stored on the iPhone. Sync everything on the phone or pick and choose from the menu you're given. Sync everything on the iPhone you don't want to lose, because a hard reset restores the iPhone to its original state and all data added since it was first taken out of the box is lost. <li> Go to the "Summary" tab at the top of the screen and select "Restore" from the drop-down menu. <li> Wait as the iPhone hard resets. The iPhone comes back up in it's original factory state and a prompt appears asking if you want to restore data settings. <li> Select "Yes" to restore the synced data to the iPhone.</li></ol> <br /> <br /> <br />
on Mar 02, 2011 • Cell Phones
2answers
I dropped my phone now it's completely black the touch buttons light up but the screen don't work at all and can't see anything how do I fix it. Also will I lose everything on it if I fix it
Could you pls provide more specific info about your phone, such as the phone make/model, provider, even region, whether the phone is under warranty etc. It seems the internal hardware is ok, but screen is having damage. Did you try making/receiving a call (if possible) to see whether all those function. If you could, a screen replacement might do the trick. If you are savvy enough, just google "your phone model no" + screen replacing ( or assembly) and you can buy most screens on ebay.
I asked for your provider & region because, I or somebody else could offer an advice regarding your carrier phone replacement policy. It doesn't hurt to give them a call and inquiring the possibilities of getting a new phone too.
Feb 27, 2013 • Cell Phones
I dropped my Iphone 4s on the floor. The screen went black, and wont turn on. When i connect it to the charger is does not do anything. When i connect it to my Itunes it wont regonize it. what do i do?
I suggest you take your broken Iphone to a cell phone repair shop.
Get a quote for the repair then you can decide whether to go ahead with the repair or get a new Iphone.
My iPhone screen won't come on but i can receive and answer calls
take out sim card on the side hold power put back in sim card
1helpful
I just replaced my lcd on my iphone 3G. It was working fine until I dropped it. Now the screen is black. I can hear it charge and get incoming e-mails but I can't see anything. Could it be my lcd again?
Hi,from the problem you are experiencing it's obvious that the problem is from the lcd screen,the shock it sustained when it dropped is responsible for the damage on the lcd screen again.
The solution is to replace the lcd screen but you have to be more careful with the phone,the iphone is a very fragile phone which should be handled with extra care,if the screen is replaced and you mistakenly drop it again,i'm sorry,you will have no choice but to keep replacing the screen,which is not good enough for you economically and also for the efficiency of the pone.
Thanks and take care
2helpful
Hi
David
CellUnlock.net
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Oloyede Monsuru
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
