Question about Mitsubishi VS-50609 50" Rear Projection Television
Green light comes on for a few seconds and cuts off
Tryed to unplug 2 hrs. pluged back in and pushed a/v input then cut on it did then same thing.unpluded 2 hrs. pushed menu&input at same time for 5 sec. andcut on ,same thing
Posted by kenneth topping on
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: My 2001Mitsubishi 1080 hd Won't come on
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Posted on Nov 05, 2007
Paul Buscema
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
Anonymous
  • 463 Answers
SOURCE: TV green light comes on a few seconds and then
Sounds like the TV is in an error condition, and will not stay on (I know... duh).
The decision you need to make is whether or not the TV is worth calling an on-site TV company to diagnose and then perhaps fix the unit.
Best guess is:
$100 house call by "Atomic Television Fixers"
and $250-$400 for whatever control board is bad.
Again, how bad do you want to keep that television around...
Oh, by the way, that TV was probably delivered in one piece, but it will come apart in two major pieces for movement in tight places or removal from same. This procedure is described in the literature that was in the box when your television was delivered.
Best of luck,
Rob
Posted on Mar 04, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Mitsubishi model Wt-46807 Power shuts
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 16, 2010
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
The DS Green Light Cuts On But Shuts off after a few seconds
I dont now about the sound but for the battery is that the ds charge battery is over! if you see backwards you will need to open it and buy a new battery thats all!!!!!! I try it it works
Jun 06, 2009 | Nintendo DS Lite Console
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
Mitsubishi VS-50609 50" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
