The tub is off balance and is very noisy during spin cycle
SOURCE: High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
SOURCE: make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
SOURCE: motor just hums during spin cycle
This sounds like the drive belt may have snapped off. It's usually located on the bottom of the washer. If you're able, tilt the washer on its side and recover the broken belt. It usually connects from the drive motor to the tensioner, then to the transmission. Take the belt to your local appliance parts store so they can match it up with a replacement. You may want to copy down the actual model and serial numbers down so the parts counter can provide a more accurate and exact replacement. Please let me know if you need any further help with this.
I hope this helps! :)
