Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
Galaxy-saturn-base-schematics my-saturn-base-power-supply-is-bad
Posted by wayland-mason on
Robert
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
C b tricks.com
Posted on Feb 28, 2013
2 Related Answers
thndr143
  • 141 Answers
SOURCE: schematics for a galaxy saturn base
Galaxy Schematics
Posted on Jan 30, 2010
Mister 44
Jim Verge
  • 35 Answers
SOURCE: How do I adjust echo on galaxy saturn base?
Inside of the cabinette there is a small pc board located on the right side of the chasis. It sits vertically and has a metal cover on it. There are 2 potentiometers on the board. One is for depth of echo and the other is for speed)
Posted on Apr 12, 2010
Galaxy Saturn Turbo EXPORT CB BASE STATION. What number are the power and modulation pods on this unit please.
Question edited for full make model (what it is).
Question moved from Saturn Cars to Galaxy CB Radio category.
Tweaks and mods in the link
https://www.google.com/search?q=Galaxy+Saturn+Turbo+power+and+modulation+pods
Is there a diode inside a galaxy dx99v that could be blown and not letting it turn on ?
Yes there are diodes in the power supply, but it could be a fuse, resistor fuse, or a bad switch, a host of things. You need to take it to a tech unless you have schematics an a good VOM.
Recive trimmer on a galaxy saturn
Its a lot more work then you think but it can be done . you should do a serch for a service manual online and work off of it.
Modulation fades in and out
Would like to help just no enough info. transmit or reception?
POSSIBLE
Power cord/connection.
Base i would assume not to be moble your power supply weak.
Radio capacitor bad on pcboard of radio.
Failing element in mic.
Short in mic cord ...intermittent
AGC circuit of radio which equalizes volume
Need to kwon the numbers for the galaxy santurn base radio to repair it cause the one it has dont belong to it.
What are you needing can you explain more detail. And all the exports base radios are the same schematic as. Are the mobiles. The galaxy 33 and gal 99 are the same radio just the 33 doesn't have the ssb parts
3answers
L32wd22 power supply
Hi and welcome to FixYa,
Based on your requirement, pls try:
Good luck and Thank you for using FixYa. Happy Holidays.
4answers
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Galaxy dx 2547
Hi Joey,
It sounds to me that the power supply you are using may be a little under powered. It's not really a bad problem as long as the voltage doesn't drop below about 10.5 - 11 volts. As for the Galaxy. I'm not real certain of the question but a Galaxy will usally use more current to make it work properly, so I would suggest a bigger ( more amps ) power supply.
Good Luck and I hope this has helped some
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
Galaxy 88hl stuck on 24.178
Hello radiogeek,
it sounds like you have a bad voltage regulator since you are indicating that the voltage adjusted by L17 is random. Check all of your voltages from the power supply (regulator side), and make sure they are stable. You will find that you may have a bad voltage regulation circuit or a bad capacitor in the unit power supply.
Thank you,
Shuttle83
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Johnny 1000
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
