Question about Kitchen Appliances - Others
How long can ground beef stay good in the refrigerator if it is in a vacuum sealed bag?
Posted by roger nori on
joel marks
    Champion:
    New Friend:
  • 217 Answers
I wouldn't trust it after one week, especially because ground meat spoils faster than other forms
Posted on Jan 30, 2013
Beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
When I use my Powerglide Pet bagged vacuum cleaner, the debris does not go into the bag but on top of it. What should I do?
Usually there is a "seal" to make sure the dirt goes into the filter.
I guess the air flow is bypassing the seal somehow. Is the seal clean, is it in good condition?
Are you sure you have the right bag?
Mar 09, 2015 | Top Vacuums
Can i defrost a piece of beef cook it slice it then refreeze it
Yes you can. If it is roast beef you might want to freeze it in beef gravy. Make sure it is sealed real good and use freezer plastic bags or if you have a food sealing device to vaccumm seal it. Deep Freeze meats cooked or uncooked last longer in a Deep Freezer as well!
Oct 13, 2014 | Refrigerators
Is it okay or not... freeze meat, thaw, grind, refreeze
Yes, that would be okay. I do that all the time with my meat.
Thanks -Oscar
Mar 05, 2011 | Computers & Internet
I have an older model Electrolux canister vacuum and it turns off quickly after turning on and this checkered light comes on. It happened right after i finished cleaning the ashes in my stove which i...
Make sure there is no obstruction anywhere along the hose. Also properly clean the filter and collection bag. This may have become blocked due to the fine ash, sort of sealing the bag.
Jan 02, 2018 | Electrolux Guardian Bagged Canister Vacuum
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
I have a canister vacuum. I replaced the bag and now can otn get a good suction. Could it be the rubber seal near the bag?
The case that encloses the bag may not have been closed properly, or a part of the bag got caught in the seal of the case. Take the bag out and reinstall. Hope this helps!
Mar 12, 2010 | Vacuums
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Kitchen Appliances - Others Logo
125 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
