Question about Kitchen Appliances - Others
What does vacuum packing, or vacuum packaging, mean?
Posted by roger nori on
joel marks
    Champion:
    New Friend:
  • 217 Answers
Vacuum packing is a method of packaging that removes air from the package prior to sealing.
Posted on Jan 30, 2013
I have almost the returns to send to Amazon can I group them bundle them in as less packages
-You mean you want to return couple packages and pack in 1 package to return to Amazon ?
-I think you can but make sure all the items you return must have
authorization before you return.
Good luck
mai
May 16, 2017 | Amazon Computers & Internet
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
I have a pack of smoked turkney necks in the refrigerate been there since April 2016 is it still good to cook?
If you have kept them in the freezer, they are fine.
If they are in the refrigerator, they may not be fine, unless you are blessed, or they are is a vacuum-sealed bag.
When you are ready to deal with them, open the package and smell it.
If it smells fine, try to cook it, and smell it.
If it will not pass the smell test, try to find a nice doggie to bless with this gift.
Aug 04, 2016 | Grilling
My order is missing one item
contact the department from where you bought the order and put in a a claim for the extra book or a refund for the book
Talking on the phone to people gets really good results.
Feb 20, 2015 | Cars & Trucks
Side brush will not stay on
The only way I can imagine the side brush not staying on is if the screw that holds it on is missing. Find a similar replacement screw. Did you get a package of replacement parts with your's? I did with mine, but I bought it many years ago now. While that brush is off, unwind all the thre4ad and hair that's wrapped in that section The brush will turn more easily without that all packed in there.
Aug 23, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
What size belt??
The Eureka Whirlwind 4489 uses style U belts, and you can find the Belt Package Assembly- Style U 2pk at the following link:
http://www.vacpartswarehouse.com/Eureka-Electrolux-Sanitaire-Belt-U-Style-2-pack-p/61120.htm
The broken belt usually stays trapped within the housing, so when you remove the necessary pieces in order to access the beater bar, you should find the remnants of the original belt, which you could also use to determine the size you need for a new belt. You might even get lucky and find that the belt itself is ok, but had gotten derailed somehow! Also good to remember is that there is often a second belt sealed within the packaging and instruction manual, so you may already have a spare belt on hand if you stashed the owner's manual somewhere.
Hope that helps! Please rate as helpful if so :) Thanks!
Jul 01, 2014 | Eureka Whirlwind 4489 Upright Vacuum
F1 PROBLEM ON VACMASTER VP540?
I found this information related to a different model of the Vacmaster:
If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
Mar 25, 2013 | Vacmaster Vacuum Pack Machines: VP540C...
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
Kitchen Appliances - Others Logo
66 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
