Question about KitchenAid KCMS145J Microwave Oven
Kichenaid khhs179ll1 fuse
Fuse location
Posted by adixon68627 on
  • adixon68627
    adixon68627 Jan 31, 2013
    Great, fixed based on your feedback!
William Miller
  • KitchenAid Master
  • 9,179 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can view a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jan 31, 2013
Frigidaire Microwave Model #FGMV176NTF Fuse location.
The fuse is located inside the microwave oven.
Oct 18, 2018 | Frigidaire Microwave Ovens
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
Whirlpool gold YGH5184XPS-0 fuse location, I believe i blew a fuse and cant find the location, the thing worked fine and then i shut the door and lost all power, either the door latch is broken or the...
Mike - Unplug the unit and unscrew about 4 screws on the top and then the side panel and the fuse will be in that location.
Note: If the fuse looks brown, it's definetly blown, you can get the same fuse at your local Radio Shack for about $0.97. hope this helps
Aug 14, 2012 | Whirlpool Microwave Ovens
Won't heat food on any setting. Could it be a fuse? Where would it be located? Don't have a manual.
Fuse will be inside the oven.And with replacing fuse ,you need to check the cause of blowing the fuse.Check the capacitor and transformer (physically).If they look deformed .Then change it followed by the fuse.
Thanks
Please rate my work
Sep 17, 2011 | Daewoo KOR-630A Microwave Oven
Kichenaid microwave khms155lss-4 doesn't work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 15, 2011 | KitchenAid Microwave Ovens
I have a kichenaid microwave#khms155lss-4 my son put a stainless steel bowl in it and i dosen't work help its only 3 years old
It's most likely a blown magnetron thermostat, but you should also check the fuse and the oven cavity thermostat.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the thermostats for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
Aug 19, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Where is the fuse located?
In general you can locate the internal fuse by opening up the microwave cabinet. To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Jun 01, 2010 | Westinghouse WST3504 Microwave Oven
Where is the main fuse?
Hello :
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
The picture bellow is showing a blown fuse .
please rate .
Mar 29, 2010 | Kenmore 80412 Microwave Oven
Cooks Model 2115 microwave oven will not power on when connected to the 110v outlet. Can this be a fuse problem? If so, where is the fuse located?
Yes, is probably the fuse. I have fixed several microwaves with this problem and the fuse is almost always located just inside where the power cord enters the unit. Just remove the skin (usually screws on the back and BOTTOM also) test the fuse with a micro meter. If no contenuity, replace with same size, type and rated fuse. Most microwaves are 20amp fuse.
Jan 19, 2010 | Microwave Ovens
I have a Kichenaid microwave Model # KCMS145JSS-1 No lights, no readout, completly dead. Power source checked and o.k. Any thoughts?
I would suspect the fuse, the magnetron's thermal cutout / thermostat, or the oven cavity thermal cutout / thermostat.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
You can download Kitchenaid owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | KitchenAid Microwave Ovens
KitchenAid KCMS145J Microwave Oven Logo
215 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
