I have a G6 where the light went out on the center console floor shifter. The light illuminates park, reverse and drive when functioning properly. The local dealer stated Pontiac used a LED and in turn requires the entire shifter assembly be replaced to fix the problem. Has anyone found a less wasteful solution for this?
SOURCE: Engine Seized up on a 2006 Pontiac G6
check the oil and coolant levels. if coolant is low pull the sparkplugs and try to turn the engine over if still not turning free remove the serpentine belt and try again, if it turns over ok check the pullyes on the front of the motor to see if they all turn free by hand. a serpentine belt can prevent an engine from turning over if a tensioner, idler, water pump, alternator, or power steering pump is siezed up or starting to seize. being your battery is bad I'm thinking probably the alternator is seized. hope this helps mike.
SOURCE: engine light 2006 pontiac g6(reset)
first be sure that its the engine light and not the "service" light. the service light will usually illuminate if its time for an oil change. if its the service light ur owners manual should tell u how to reset it. if its ur engine light then try disconnecting ur positive battery cable for 1 minute. that should reset ur ecm and get rid of the engine light. if the engine light comes back on then have a diagnostic scan done to determine whats causing it. LJ
SOURCE: replacing drivers side air bag on 2006 pontiac g6
irst, You must get the steering wheel with controls. I believe part numbers were listed above, but bottom line, make sure you get the right color if you are ordering. The black one is called ebony. Prices vary depending on where you get them. I got mine from a salvage yard brand new for $75. Second, You must replace the clockspring with the column harness. If you have a light duty pickup, you will need part number 26101829. This is for a 2 stage air bag. If you have a heavy duty, order part number 26101828. This is for a single stage air bag. If you are unsure, take off your airbag and look to see if it has 1 or 2 pigtails connected to it. 1 is a single stage, 2 is a 2 stage. GM has reduced the number of part numbers available to simplify things. Therefore, you will get a harness equipped with an additional 8 pin connector. This is for the steering wheel speed sensor for quadrasteer. If you do not have quadrasteer, just tape it to the column and don't worry about it.
Be careful when installing the harness, there are about 14 connectors, I spent 2 hours installing the harness and wheel.
SOURCE: Pontiac G6 radio
probably not but the switch over is ez you probably need a harness..thats about it..
SOURCE: replace the pontiac G6 center console light
You should be able to open the cover piece that holds both lights. This piece if you take a flat head screwdriver carefully, just pry the plastic cover (not the actual push buttons), and release it. You should now have access to the lightbulbs for replacement.
