Samsung AQV36JA Classic 36000 BTU Single Zone Ductless Heat Pump Mini Split Air Conditioner System Logo
A
Anonymous Posted on Jan 30, 2013
Hi am working on 36000btu samsung unit heat pump indoor turn on.but the outdoor don't run
1 Related Answer
Anonymous
  • 127 Answers
  • Posted on Aug 24, 2011
SOURCE: I have a contractor that
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
My heat pump froze and now has an E-6 error on screen and does not run
Lost communication between indoor and outdoor, did you shut both indoor and outdoor off?
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
I have carrier heat pump nothing is running indoor or outdoor unit
check that you have power to indoor unit 120volts if yes check fuse on control board of indoor unit check control board for 24 volt the indoor unit controls the outdoor unit
Does not heat - compressor switches on/off repeatedly
check outdoor fan if running. the outdoor coil will freeze up on heat cycle. or outdoor board if there is one is defective.it could be reversing valve as well
Heat pump not running
Depending on the age of the unit it could be several things, does it have a circuit board? Contactor could be bad, freon leak if it has a low pressure switch, burnt wires, connections, etc. Do a complete visual and check for 24 volts, does the indoor unit run? Transformer may be bad.... No indoor unit - no outdoor unit, most of the time the outdoor unit gets its 24 vac power from the indoor unit which runs them both, look for fuses (like car fuses)..
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
