Question about Toys
Play doh candy cyclone jammed
The gears jammed inside the gumball factory, so I took it apart to inspect it, fixed the issue, but now the 3 fluted cones that shape the gumballs aren't facing the correct direction to form the balls... Can you show me how to position the gears so the cones sit right?
  • Rachel Smith
    Rachel Smith Mar 02, 2017
    I'm having an issue with the insides, mainly the piece with the spring underneath won't allow gears to turn. any help?
Eric
    New Friend:
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Posted on Feb 23, 2013
  • Tania Lempert
    Tania Lempert Nov 06, 2014
    Could you tell me where to find the arrows on the gears? Thank you.
  • James Oct 04, 2020
    Each hear has a dot and an opening: These are the arrows
C/E light on for 1 code P0741, changed TCC solenoid, trans fluid, filter why would the transmission stop going into gear after previously shifting beautifully with no slipping or any issues at all.
Just because you installed a new part, do not assume it can't be bad. This happens alot with aftermarket parts. When you change just a minor part and a problem develops, good idea to double check both your work and the new parts.
Apr 14, 2015 | 2002 Cadillac Seville SLS
Where do I find a picture showing internal parts for gear box on Stihl KM130 Hedge Trimmers
we have require heavy gear box inspection tool without opening the top cover
Jul 07, 2012 | Stihl KM-130 Hedge Trimmer
My skull candy ink'd left bud broke apart,how to re-wire it.
The wires inside the cord have broken, Unfortunately there is really no easy way to fix it, they don't solder well and replacing the cord is the only option but this also may not be successful. Replacing the headphones is the only proper solution
Mar 01, 2012 | Skull Candy Audio Players & Recorders
If the Play Doh has been left out and become dry, how can I rehydrate it? Can I seal it in its container with a moist piece of cloth, or add some type of oil?
try the official play doh site
http://www.hasbro.com/playdoh/
Even if the tip does work for you ... check out the site anyway they have tons of out to make items with playdoh
This is the tip they give you to re hydrate your playdoh
My PLAY-DOH compound is drying out. How can PLAY-DOH compound be softened or moistened?
To restore the softness to PLAY-DOH compound, try adding water one drop at a time and working it in to moisten the PLAY-DOH compound.
You can also try wrapping the PLAY-DOH compound in a damp paper towel, returning it to the container and replacing the cover. Let it sit overnight
Good Luck. RJ
May 09, 2011 | Play Doh Toys
I have a 2006 dodge charger and I parked my car a the gas station to get gas and when I came back the shifter was stuck in park and wouldn't budge for nothing ! After an 1hr and 45min I decided to take it...
thats problem is a loose wire you can probably fix it with a little playing around it sounds like the wire is the wire that is recieving signal to release the shifter so check see if it is loose or disconnected and if you can reconnect it if take to shop around 100 bucks to fix it maybe 150 if sensor is broke or wire cant be salvaged
Sep 15, 2010 | 2006 Dodge Charger
Phillips FWC577 CD Shelf System
Hi mate , ive got this exact stereo, Great aint they . i had the same problem so i stripped it down , took apart the CD platters and found some dust caught between the gears, you can look for the service manual on the internet as thats where i had my help from. Dust can corrupt the laser , jam the eject gears.
If you want some more help reply back on here.
regards jonno
Sep 01, 2008 | Philips FWC577 CD Shelf System
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Toys Logo
2,029 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
