SOURCE: panafax uf-890
The likely hood is that someone has turned off auto answer check the manual how to change this the other option if it always did auto automatically then turn the machine off at the wall socket and then turn back on this will boot back how it was. (try this first) If it doesn't work then check that the auto answer is switched on.
If none of the above work then it will be the modem that is not picking up the line and will need to be replaced.
Hope the first solution helps you
Thanks J
SOURCE: Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
SOURCE: How to change the date and time
press
function
71
set
key in the date and miltary time
set
stop
