Off idle miss
and I'm out of ideas.
I have a RR 125 Motard with about 12000 miles on the clock. It's been trouble free for the years that I've owned it. Recently I noticed a slight miss when running at part throttle. RPM doesn't matter it misses from idle to almost redline but only when the throttle is in the first 5% of it's range.
I did the full routine, carb cleaning, valve adjustment (ugh...shims), air/fuel/oil filters. No change.
At more than 5% throttle, there's no miss, and it pulls very strong. At full throttle, I don't have the guts to see the end of 4th gear.
Tempurature doesn't make a difference, hot or cold, it runs the same, although when the choke is on (cold) there's no miss (but a high idle). Turning on the choke after it's wamed up it will bog and die (like it should).
I suppose I could have missed something when cleaning the carbs, but usually, a little bit of choke will fix that. Not in this case.
There's no hesitation when opening the throttle, and under high loads, any RPM, any gear, it runs fine.
So, I'm at a loss. I'm open to suggestions. ,Check for vacuum leaks first - carb boots, vacuum lines, etc. Also check the CV diaphragms for cracks, splits and pinholes. Then, I think I'd re-check/clean the pilot jets. Then, if that doesn't help, I'd open the idle mixture screws a bit - maybe 1/8 to 1/4 turn to get a little richer mix.,,,
