Already opened the back and adjusted the picture, no help, changed input points for video, no help. had cable guys check their box, no help. No transistors appear to be damaged, but that is out of my skill sets.
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
SOURCE: Sony KV-32XBR400 television
Four blinks would normally indicate a yoke winding that was shorting intermittently, 5 blinks something on the "D" board in overvoltage condition and 6 blinks commonly Ic6501 is failing...
To have all of these blink codes happening could be signal derived, thereby not affecting dvd play. Could be smps related or possibly regulation. My first guess would be the "D" board...
Is there a cheap and quick fix, yes and no... This isn't one you'll be able test out or you wouldn't be asking the question. But a shop should be able to determine the problem and repair for less than half the cost of a new Tv in it's comparable class..
Hope this helps!
Bill
SOURCE: set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
SOURCE: sony tv KV-27FS120, blinks 6 times, horizontal transistor is good, and driver to, can you help me?
check the memory.
SOURCE: Sony Trinitron TV - Keeps Blinking
Try this link
http://www.agoraquest.com/searchbb.php?addterms=all&forum=all&sortby=p.post_time&submit=1&term=trinitron%20blinking%20picture
pls rate my suggestion....
