SOURCE: Flooded in Katrina
Try hotairing (set 4 to 5, medium airblow)the main board, check also the mechanical connection or terminals ( I assumed you already did that).
SOURCE: Sony Handycam Cords
thanks and there is one it is the a/v output.. there is a convert end on the svideo cord to that goes into it
SOURCE: SONY camcorder DCR-HC42 color stripes
Try with the side display closed. Does the viewfinder show the pix OK? If so, then the problem is isolated to the LCD display. There is a small ribbon cable between the camera body and the LCD that sometimes gets a small crack in it. Replacing the cable usually fixes the problem.
Dan
SOURCE: sony ccd tr517
thanks for your help, i was doing a research and found that the part is fp-220
