When i push the start button the starter spins but does not engage
SOURCE: When I push the starter
need more information, what do you mean "nothing is engaging"
is battery dead? have you tryied boosting it?
SOURCE: I changed my starter and
Replace the "Bendix" unit on the starter shaft in the primary. It's basically a one-way bearing designed to lock up when turned one way and to freewheel when turned the other. When the starter turns the "Bendix" it locks up but when the engine starts, the Bendix turns the same way but faster. This make it reverse directions in relationship to the starter shaft. When they go bad, they either don't lock up at all or the "jump out" once started turning the engine over.
Do not use a cheap Bendix replacement (made in China). You'll be back in there again in six months if it lasts that long. I like the Accel units made in the U.S.A. Clamp the shaft in a vise with "soft jaws" on it and take the nut off the end of the shaft. It has left handed threads.
Good Luck
Steve
SOURCE: Push the start button on my 94 fatboy. Will not
If you're saying that the new battery will not start your bike but when you jump the battery in the bike, it will, I'd say you have a problem with the new battery. When you "jump start" any vehicle by connecting another battery to your battery, you're connecting the batteries in parallel. This keeps the voltage the same but adds the current capabilities of the two batteries together. You either don't have enough battery or your starter is drawing too much current. Check all your connections and see if they're clean. What kind of battery did you buy? It should have been a stock replacement battery of the same size and current capacity.
Good Luck
Steve
