Question about Panasonic KX-TGA101S Cordless Handset
I want to change the greeting on my outgoing voicemail and cannot remember how to do so? I know I pushed a particular button and held it but it's been years since I've needed to change.
Posted by lisaweydert on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
The TGA-101S isn't an answering machine, and thus doesn't have an outgoing message. Please consult the documentation for your answering machine, or else repost your question specifying the make and model of the answering machine.
Posted on Jan 30, 2013
3 Related Answers
Anonymous
  • 214 Answers
SOURCE: I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Posted on Feb 01, 2009
Anonymous
  • 12 Answers
SOURCE: changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
Posted on Jan 18, 2010
  • 102366 Answers
SOURCE: i need manual for the panasonic kx-tga510m
The KX-TGA510M isn't an answering machine. Please consult the documentation for whatever answering machine or voicemail system you have connected to your phone line.
If you need further assistance, please repost your question specifying the make and model of your answering machine.
Posted on Sep 04, 2012
How do I change my outgoing voicemail message?
Depending on your wireless service provider, the method for changing your voice mail greeting or voice mail password might differ. You should be able to access the options for changing your voice mail greeting or voice mail password when you check your voice mail. For more information, contact your wireless service provider.
Oct 02, 2014 | RIM BLACKBERRY TORCH 9800 TOUCH SCREEN...
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
Cannot record outgoing voicemail greeting
It's not in the manual for the good reason that the AT&T 992 isn't an answering machine. If you want to record an outgoing voicemail greeting, you'll have to do it on the voicemail system, not on the phone. If you need instructions on how to do that, you'll have to tell us the make and model of the voicemail system or answering machine.
Nov 25, 2013 | AT&T ATT-992 Corded Phone
Record an outgoing voicemail greeting
Record outgoing voicemail greeting
The AT&T 992 isn't an answering machine. If you want to know how to record an outgoing voicemail greeting, you'll have to tell us the make and model of the voicemail system.
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
here you go...
message
1 {MENU}
{OK}
{OK}
6 {OFF}
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
Panasonic KX-TGA101S Cordless Handset Logo
316 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
