How do you access the back side of the suction assembly from the tub side?? I need to access the 1/8" tubing connection & level sensing switch in the suction assembly to determine if the tubing is disconnected, broken or if the sensing switch is bad. It appears the only way to do this is to remove the entire suction assembly from inside the tub. How is this accomplished?? If the suction line is clogged, can the it be blown out with compressed air from the other end of the tube at the control box to clear the clog??
The chances that is problem you are experiencing is related to the suction cover is extremely remote. The suction assembly doesn't have anything to do with the tub motor operating.
The issue is most likely with the motor not working or the air switch in the motor malfunctioning.
What does the control look like that you use to turn the pump on/off?
Is it an air button or an electronic switch?
SOURCE: How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
SOURCE: Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
SOURCE: Install of AS 2425 whirlpool tub
hey bill no easy way what we do is measure height of edge that will sit on stud and tack stud in tub area and dry fit tub.when you do that you can see how much space is under tub for your mortor you should use light weight cement called structolite its white and not as heavy and yes a piece of tar or resin paper is a good idea
SOURCE: hot tub jets stopped working
yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
SOURCE: clogged suction line in bath whirlpool
It sounds like something got sucked into your pump impeller, you can try sucking it back out with a wet vac but my bet is that you'll have to open the pump to clean it out. If the marble skirt is the only acccess to the pump it will need to be removed but look for another way first, they can be difficult to reinstall and make look good. If your careful, the pumps can be opened and cleaned without much trouble, Use your wet vac to suction anything left out of the pump suction line and make sure the pump discharge and distribution lines are clean as well. Pump case should have an "O"Ring seal that should be replaced but may be cleaned, lubricated and reused if not dammaged
Good Luck, this is the kind of job the service tech's make there money on.
