Need to find replacement panel.
I'm a little confused. What part you need depends on whether you have a display issue or an issue of some pads on the keypad are not responding.
Please post a new help request with your full model (thanks for that) and more detailed symptoms.
SOURCE: cannot open the door Dacor Model DMO24S
You will need to remove the outer wrapper, then separate the control panel from the microwave by removing the screw and then lifting the panel up and away. If you disconnect any wires, be sure to mark them, make a diagram or take photos first so you get them all back exactly where they were. The attached photo shows the area where two locking tabs are located. They must be gently pushed in to allow the door open button and spring to be removed. The door open button is part # 86778 (if your oven is black or stainless, part # 86778 if your color is arctic) and it can be obtained from a Dacor distributor such as http://www.apdepot.com This should be the same as a Sharp model R330BK (black model) and you can order that door open button from Tritronics. It is part # JBTN-B088WRF0 and they are at http://www.wehaveparts.com
SOURCE: Dacor DMO24 microwave oven door stuck
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed. Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Dacors are made by Sharp, and one of these service manuals below may help you.
http://www.microwavedisplay.com/r530es_sm.pdf
http://www.microwavedisplay.com/R530EKF_R530ESF_R530EWF_sm.pdf
http://www.microwavedisplay.com/r530bk_bw_sm.pdf
To order Dacor parts, I recommend you visit http://www.apdepot.com/index.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Display panel is scrambled on my Dacor DMT2420 microwave.
There are two options for this model:
You can order our exclusive modified control unit with our proprietary upgrades
for $135, then if you return your defective control unit in repairable,
good cosmetic condition, we'll give you a core refund of $40.
For
details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
For
We're
happy to help you with free advice and we'd appreciate your
SOURCE: My Dacor Microwave screen has gone blank. Can
try this guy...
SOURCE: Microwave oven light stays on and turntable keeps turning
It would appear that relay # RY1 is stuck on your control circuit board.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
We have
the service / repair manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
William E. Miller, AS-EET
[email protected]
