Disconnecting the battery cable while the vehicle is running is a no no ! The electronic's on your vehicle , you can cause some serious problem's doing that . That was ok on 1960 era vehicles , from 1970 on with all the transistors in the electronic control modules ,you don't want to do that . You may have caused your problem yourself ! http://www.troubleshooters.com/dont_disconnect_battery.htm .Take your vehicle to a qualified repair shop .
If you have a outside sensor add betteries.Wait for it to connect to the base. You may have to "reboot" ,remove batteries from base and outside temp sensor and replace both, Patiently WAIT I have a similar device and once a year I replace the batteries It takes a while for the devices to re-connect and set , the atomic clock as well. That said, How far is the Temp Sensor from the base unit? I set my outside sensor near the base to connect and move it on th outside porch (30' away) out of the direct sun and rain. I not sure if this is necessary but that the way I reset them.
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only. www.serendipity-gifts.co.uk
TAKE BATTERY TO AUTO PARTS STORE FOR A LOAD TEST PROCEDURE, MAKE SURE THE CASE IT IS PUT IN HAS THE DOOR CLOSED FOR YOUR SAFETY, BATTERIES SOMETIMES DO "EXPLODE" AND ACID FLYING IS NOT GOOD. IF BATTERY IS NOT GOOD, I WILL SUGGEST YOUR BUY AN AMPHOROUS SOLAR POWERED BATTERY CHARGING PANEL, THEY COST BOUT 30 BUCKS AND WILL KEEP YOUR BATTERY CHARGED UP OVER LONG PERIODS OF TIME.
A Dell Mini net book is a small and very portable laptop. The compact
size makes it a good candidate for travel or just simply using around
the house. Outdoor aficionados can get the most computing life out of a
Dell Mini by finding a way to charge the battery outside. One method
works when you are near a building while the other can be used for more
remote outdoor locales
Things You'll Need
Extension cord
Solar laptop charger
Dell Mini power adapter
Plug an extension cord into an
available power outlet. Run the extension cord to where you are outside.
Many homes also have exterior outlets. Use an extension cord that is
designed for outside use. Plug the Dell Mini power adapter into the
extension cord to charge the battery.
Purchase a laptop solar charger.
Solar chargers are available from several different manufacturers and
may come in the form of a roll or be built into a case that closes up
for travel. Depending on the charger, you may also need to purchase a
Dell Mini power adapter. Some chargers work with a Dell Mini cigarette
lighter adapter that is designed to plug into a vehicle's power port.
Place the solar laptop charger
in a sunny location. Open up the case if the charger is in one and roll
it out flat or unfold it to expose all of the solar cells.
Connect the Dell Mini power
adapter to the power port on the solar charger. Connect the other end to
the netbook. The adapter will regulate the charge coming from the solar
panel and recharge the battery in the Dell Mini.
Tips & Warnings
Solar chargers
offer less power than a wall outlet. They can be used to extend the
battery life of a Dell Mini or to recharge the battery when the netbook
is off.
Some solar laptop
chargers are relatively heavy. Take the weight into consideration if you
are going to be backpacking or otherwise carrying it on your person.
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Sounds like then fan has died or the run capacitor has die. All motors that run on single phase mains need a capacitor to start them spinning. These are quite cheap & simple to replace usually - worth just replacing if you feel you can't test it. Looks a bit like a 'D' cell battery with 2 leads hanging out.
Could also be that the unit is not cooling/heating and the temp sensor will not activate fan until heating/cooling coolant has passed room temp. - Rick
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
could well be the battery has just gone flat starting the engine up and running it for a fuw minuets knocks more out the battery that you put in and batterys dont like cold weather any how if your going to leave the bike standing around not being driven go out and buy yourself a 12 volt 2.5watt solar charger hook this to the battery and it will keep the battery toped up even in dull weather,,,,i have them on my bikes all year round,cheap power!!!
