Question about Dell PowerEdge Computers & Internet
Replacing Server HDD
Hi, I have a Dell PowerEdge R710. The HDD in the system have 32mb cache. Would it be okay to replace them with HDDs that have 64mb cache? HDDs are same speed and transfer rate.
Posted by bryan on
Hans Pedersen
  • Dell Master
  • 3,606 Answers
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/poweredge-r710
Yes, that will be okay.
But a SSD harddrive is much faster, than the old mecanical one.
I know they are a little more expensive, but you will see a speed improvement, you have newer seen before.
Good luck
Posted on Jan 29, 2013
2 Related Answers
Anonymous
  • 5 Answers
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Posted on Jun 07, 2009
Anonymous
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
Problem to install poweredge r710 can nor detect sata hard disk
That is an impressive piece of kit. Is it under warranty ?
You should probably have it professionally serviced but you can always check whether it detects a known good drive. You can also test the suspect drive in another system.
Before you do anything ask yourself: What changed last (or recently)? There find you will that which disturbs the force.
Make sure that the connectors are all fully inserted. This means both the power and the data cables. Try different cables and a different power plug.
Sep 01, 2012 | Dell PowerEdge R710 Server (D263K)
Installing Dell PowerEdge R710 DVR Server
  1. VIA a serial cable (looks like monitor cable is not). You have use something like telnet. Old school and very technical.
  2. Just connect a monitor, keyboard, and mouse and treat like a regular PC. Can't go wrong.
Aug 21, 2012 | Dell POWEREDGE R710 E5520 226G 2P 4GB...
Hi , seagate 1tb Expansion portable drive S/H: 2GHY01LD error in page operation plz help
Go to Start, right-click on My Computer icon and select Manage
When you go to manage, select Disk Management.
Click on Disk Management and you will notice all the disks (HDDs and any removable devices on your right column.
Click on the Seagate 1tb HDD,
(1) Note the file system
(2) Note the Status of the drive
(3) Note Fault Tolerance
(4) Then Notice the HDD if it is Basic or Dynamic
If the HDD is Basic, right click on it and create a partition.
Then move some of the Data on to the new partition to free up the old partition. Restart the computer and abserve the results...
That usually happens when the Hard Disk driver is running out of space or you have less RAM..
Aug 23, 2011 | Seagate 1TB 7200RPM 64MB CACHE...
Dell PowerEdge R710 Installation error I have the same problem while installing Windows Server 2003 installation process reach to the step asking press F8, when pressing F8 it says no Hard Drive were...
ok you will need to get the windows 2003 drivers for your raid controller and put them on a floppy disk. when you first boot off the cd you will see a prompt to press f6 if you need to install any additional drivers. insert the floppy disk and select which driver you wish to load.
you should be able to see the hard drives now to partition/format.
Mar 09, 2011 | Dell PowerEdge R710 Server (D263K)
Suitable agp for playing gta 4
The AGP slot on this system is 4X
The two cards that were tested on this from Dell are
ATI 64MB Radeon VE 7500 ATI 32MB Radeon
The maximum card you can connect to the system any PCI video card not more than 128 MB. As the motherboard and the power supply would not support it
Thanks
Proton
May 25, 2010 | Dell OptiPlex GX260 PC Desktop
The right type of motherboard for compaq presario 2200 pc
Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371793-001 System board (motherboard) - De-featured (DEF) for Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original
Mar 02, 2010 | HP Compaq Presario 2200 Notebook
Need to add hard drive and memory to emachine tower 333
Okay, this is what you do, I don't really think that Win 98 supports dual HDDs, but I think I can help.
If you have a IDE Dual Cable (plug into the Motherboard and have two connectors attached), Do you see the mini plug by the connector on the HDDs? (Usually white or different color) on the Original HDD, put the miniplug to "Master" and the second (added) HDD to "Slave" or you may be able to use the "Select" on both.
What I do recommend though is going ahead and burning all of your precious data to CDs and buying a newer HDD.
Instead of 4 Gigs, get something around 80 Gigs.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2948583&CatId=134
If you give me the motherboard specifications, you may be able to update your RAM to 128-256 MB
Mar 09, 2009 | Microsoft Windows 98 Second Edition for PC
Dell PowerEdge 1800
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
Nov 09, 2007 | Dell PowerEdge 1600SC Server
My operating system will not load
Try removing all of the hdds or just leave one that you think it works. See what happens.
Nov 07, 2007 | Dell PowerEdge 2500 Server
Open Questions:
Computers & Internet Logo
187 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
