It's probably your phone-line that causes the problem. The fax-module in your machine needs a 100% analog phone line. HP garantees nothing when using IP/ISDN/PABX-lines. Try lowering the baud rate, turn off JBIG compression and error correction mode, but if the problem remains, you better replace your phoneline.
Go into wap settings in your phone and add new connection and use these settings.
Fill in the following fields: (some of the fields may already be setup)
Name: mMode Homepage: http://home Service Type 1: WAP Gateway IP 1: 10.250.250.250 Port 1: 9201 Domain 1: <leave this blank> Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 8080 Domain 2: <leave this blank> DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 5 minutes CSD No. 1: <leave this blank> User Name 1: <leave this blank> Password 1: <leave this blank> Speed (Bps) 1: 9600 Line Type 1: ISDN CSD No. 2: <leave this blank> User Name 2: <leave this blank> Password 2: <leave this blank> Speed (Bps) 2: 9600 Line Type 2: ISDN GPRS APN: proxy User Name: <leave this blank> Password: <leave this blank>
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of: - Cost - Reliability - Security. ADSL would be better.
I had the same problem with heavy packet lost after 10 minutes connection between Singapore and USA. We are using ADSL line and Sony PCS-G50 for video conferencing. After a much trouble-shooting, we identified that the nature of the problem lies with the Internet Service Provider's back-end server. The server has difficulties handling large and constant data packets. This could be due to the reasons that ISP using routers with more hops and small pipes. We immediately changed the ISP to a more reputated one (with better infrastructure) and now, we have a much better quality video.
