Anonymous Posted on Jan 29, 2013
In studio recording, which instrument is usually recorded first?
Norma Garcia
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Apr 08, 2014
Norma Garcia
Expert
Level 2:
New Friend:
Answers
44
Questions
Helped
24560
Points
122
When I record I always start with guitar then vocals since I am a solo artists when using bass and drums those two instruments are first then guitars and finally vocals sometimes we do live recordings
Anonymous
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Jan 29, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
152
Questions
33
Helped
89278
Points
467
Usually the drums are recorded first so that the other musicians can later play with different keys and play their track along with the rhythm of the drums
Im Using Acid Music Studio 8.0 With & Xenyx502 Mixer. Every Time I Record It Sounds Fine But When I Play It Back When Im Finished Its Off Beat How Do I Fix This??
check the "buffer" setting - set to the lowest number possible. You can't eliminate the "latency" but you can reduce it a lot. Also 0 try to monitor what you are recording with "live" sound (input instead of output) - also, you may need to download a different driver for your audio card, try ASIO4ALL
When I record & play it back my recording take is off beat
you have too much latency in your setup. Try using ASIO as your audio engine in your recording program. Also, shut down all unnecessary programs running on your computer to get better performance.
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Can I setup home recording studio all in 1 room
Wow what a question!! The short answer is going to be yes. The longer one will need to know a lot more about the room, what you are trying to record, if the artists are going to be in the same room, what sound deadening you will have if so, what sort of instruments will you want to record concurrently (as acoustic instruments including voices can be problematic if the room isn't big enough or the room is too alive)
2answers
How do i record an instrumental on studio one from youtube
Electronic studio performs the remixing on the sound audio files. For example, display on the computer program the remix software from where several functions makes creating, recording or innovating music productions. usually the progrma mixer allows to create audio either produced to an external area on disk CD DVD else displayed on network sturtures. Prior to creating files on the audio mixing software, determine whether the files at complete version were displayble on CD DVD media else on the network. Several factors require predetermining the location area on where media would be displayed after productions. First, ascertaining that media would be displayed on youtube as an internet website requires to encode the sound as internet loadable. Where for example, the internet least allows entensive sound audio considering spaces available. Second, the internet web sites require compartibility. Where for example a prior determination of loading on the internet makes the formats on which creation is attained. Audio electronic studio has an enormous format record methods that require prior determination to capture the final sound audion files to be made available eslewhere. Familiarise with the audio files on audio requirements. The processes to recording audio files on the program is provided. First, the prorgam has an available method to record where examples of prior audio files allow to remix either into version preferable. Once the program has been displayed, audio windows allows to add files using where several audio clips are integrated from which becomes remixed. Observe the feature functions on the programs tools to capture an extensive remix possibilities. For example, the audio files has the features that allows to record voice that is intergrated to prior instrumental recordings either as piano, guitar or xylophone clips. Obserrve from the prior recorded collection of clips that makes possible remixing. In the sitaution where audio prorgam least has prior collection of intrument clips would require to capture from an elsewhere location either least from the computer to be installed on from where audio captures the experiences of remixing. Once the audio prorgam has been displayed on the computer, explore through the user guide to attain a tor explanation features. Refer also the product manufacturers user guide to attain methods to achieve experiences.
I was tring to record with audacity and my mic
Make sure the mic level is correct. Many of these units require line-level inputs which is much higher voltage than a mic puts out. You MAY need an impedance matching transformer for your mic.
1helpful
I'm in the studio using LogicPro with my MO8 -
In General MIDI, the grand piano is defaulted to MIDI channel 1.
IF you have a device that responds to "General MIDI" format, just send the MIDI data to channel one and you should be fine. Remember that pianos are VELOCITY controlled and usually don't use after touch so you have to generate appropriate velocity for EACH note if you are using an editor.
1helpful
Wont save over 1 song and always turns off
Try asking here:http://www.korguksupport.co.uk/page.cfm?pageid=370. Hope this helps.
1helpful
I downloaded cakewalk studio instruments into computer i get
Check to make sure all your audio drives are configured. Sometimes the microphone jack isn't configured with the program. No audio comes through. Another suggestion is to, try Audacity. It is a free audio recording program, and it helps to master even some of the hardest studio production software programs.
 Grubhead
Grubhead
SmartAviator
SmartAviator
