Question about Logitech 2.4 ghz cordless presenter
Slide changer not working - Logitech 2.4 ghz cordless presenter
Posted by Prajacta on
Hi jag xjs 1993 cd cassette wont eject as no 6 stuck in any hints on how to eject the casestte?
you would have to take the to off of the changer. If you can do that, on top of the cd mechanism is a large gear which slides the trays in and out of the magazine, If you can, move the gear so the tray slides back into the magazine. The changer will probably work once that gear is freed.
Jul 22, 2011 | Car Audio & Video
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
My Sony CD changer (CDX-454RF) won't play the first three slots, and I get error messages on other CD's and plays them when "it" wants to I guess
The changer has a mechanical slide system inside it. It may be binding up around those positions. You may want to take the cover off and reposition some of the excess grease into those slide tracks and try it again. Or you could just be happy with a functioning 7 CD changer.
Aug 05, 2009 | Sony CDX-454RF 10-Disc CD Changer
How do you open c/d changer in trunk?
front of changer has a sliding door,slide open & below cd magazine is a small button,press this&magazine will eject,this will not work if changer is disconnected from the vehicle,
hope this helps
Jul 02, 2009 | Nakamichi Car Audio & Video
My 2001 Jetta 6 disc changer has a cassette but I don't know how to get it out of the changer. Does the car need to be on?
The front of the disc changer has a sliding panel (usualy the left side slides to the right). After you open it completely either on left or right bottom (inside) you will see a little red or yellow push button. This allows to eject the cassette. No, the car doesn't need to be on, but depending if the wiring is standard or not it doesn't harm if the car is on.
Jun 14, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Logitech 2.4 ghz cordless presenter Logo
303 people viewed this question
Top Logitech Office Equipment & Supplies Experts
Christopher Stearns
Ekse
Are you a Logitech Office Equipment and Supply Expert? Answer questions, earn points and help others
