Question about Sony Cyber-Shot DSC-S500 Digital Camera
Battery door wx10 - Sony Cyber-Shot DSC-S500 Digital Camera
Removing battery
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Mar 20, 2014 | Nikon COOLPIX L6 Compact Digital Camera...
I can take pictures with my camera, but LCD screen is black, and I can not view my pictures either
Has the camera been dropped or gotten wet? If not screen is shot and needs a new one.
Jan 30, 2014 | Sony Cyber-Shot DSC-WX10 Digital Camera
Dsc-wx10 lens stuck in
Throw it away, by the time you have it serviced you will easily pay for a new camera.
Jun 16, 2012 | Sony Cyber-Shot DSC-WX10 Digital Camera
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
Battery died after experancing power door didn't close fully...
if you turn off the switch for the interior lights,an override,it will prevent the battery from going dead until you can get the door alignment or switch repaired.the interior lights,there is more than 5 will kill the battery for sure.
May 23, 2009 | 2003 Chevrolet Venture Passanger
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Battery in M-RBB93
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, close the battery door.
regards
Feb 21, 2008 | Logitech Cordless Mouse
Sony Cyber-Shot DSC-S500 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
