Question about Russell Hobbs Blenders
Require new glass jug for Russell Hobbs blender No.3901
5 Related Answers
Jose Mederos
  • 109 Answers
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
Pranali
SOURCE: REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Posted on May 05, 2008
Anonymous
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
Anonymous
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
I need to replace my glass blender for my RHMP750
FIXYA unpaid volunteers use the internet to answer questions. FIXYA doesn't sell appliances or parts.
Here is what is easily found using http://www.google.com to search the word rhmp750
https://www.needapart.co.nz/buy-online/parts-for/russell-hobbs-rhmp750
Parts for Russell Hobbs Multi Processor RHMP750 food processor Buy Online...
Mar 29, 2018 | Blenders
I require replacement blade and glass blender jug for model 14071
Presumably a Russell Hobbs though you did not say; the blender is obsolete and parts hard to source,furthermore given the price of comparable parts it would be cheaper to buy a new blender. I hate it when that happens.
Jul 12, 2014 | Blenders
Need a rubber seal for russell hobbs 18276 blender
I also needed a seal - contacted Russell Hobbs - told that product is discontinued - they do not hold stock on the seal. Great service !!
Dec 05, 2013 | Russell Hobbs 18276 Allure 1.5l Jug...
I would like blade seal
Are you in the UK? If so, I got hold of replacement parts for my russell hobbs hand blender from http://www.productcareuk.com .They have a telephone number too if you cant see it on their website.
Aug 11, 2012 | Russell Hobbs 14449 2Speed Blender
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
Russell hobbs food collection blender
Dear
karan plz cheak motor unit swith anther
plz coll me
my ph no - 23051554 \ 23095757
mumbai
Aug 01, 2008 | Russell Hobbs 3902US Work Top Blender
Blenders Logo
77 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
