Question about NEC Electra Elite 32D-1 Corded Phone
How do I fix that the nec dt3000 does not ring past a certain time
Wanting to extend ring time - changed by itself - only ringing 5-6 times before going to message bank.
5-6 rings I think that is the best you can get
link to a manual for it
SV8100 DT310/DT330/DT710/DT730 User Guide - NEC Corporation ...
https://www.necam.com/Docs/?id=5601ae16-b7e2-4e8c-a769...
NEC-10645 UNIVERGE SV8300 DT300 DT700 USER GUIDE
au.nec.com/.../SV8300_Handset_Manual-ce03fb6c-32af-4991-9bd5-8ec.
4answers
Nec business phone. When we get a call coming in the ring is too loud. Can we fix this ourselves.
HI,
Is there a volume switch on the base or side of the unit? What model is it?
Main phone for office is not ringing, console will not ring. Just blinks. If portable phone is detached, portable phone will ring. But when connected to console there is no ringing.
if the phone was programmed to ring originally on the system try pressing the volume up key a few times while you know there is an incoming call on that phone
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Tv stuck one channel
Be sure tv is set to antenna and not cable . Do auto scan . Find this in setup menu. If this does not work check the mfc website for software update. replace the main board as last resort.
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
"NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
1helpful
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
NEC Electra Elite 32D-1 Corded Phone Logo
Top NEC Lands Phones Experts
Oloyede Monsuru
ray gallant
Ekse
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
