If you reset the router and have not turned off and back on all your devices you probably have conflicting addresses. some versions of ps3 will not connect for some reason unless they have the first ip available on the router.
Turn off your wirelss on your iphone and ipad, turn off the ps3. Reboot the router when it comes back up turn on the ps3 and get a good connection, the enable wireless on your ipad or iphone and get a connection the doe the same with the other.
This will avoid conflicting addresses.
An IP address has a 24 hour lease if you reboot a router it forgets what device had whipch ip address. If you need to reboot your router you need to refresh the ip address of all your devices to avoid conflicting ip's.
In this case I suspect you ipad and iphone are attempting to use the same ip address.
