Question about Tissot T-Touch T33159851 Wrist Watch
How do I reset my tissot t touch expert
I changed the battery and now the compas,altimeter ,thermo and compass doesn't work.pleas help
Posted by Terry doyle on
  • Shaun Kris Nov 05, 2019
    What is when I get to synchro the plus amd minus dpes nothing. I cannot get the hands to move.
    Sorry an AD blocked my writing. When i get to SYNCHRO screen the hands refuse to move.
Peter Harrop
    New Friend:
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Posted on Sep 26, 2014
  • Hans
    Hans Jan 25, 2015
    thanks Peter I did it exactly the way you suggested and it worked! This after trying various other methods! also as per the manual and various other posts on this subject! thanks!! Hans
Watch4maker.com
    New Friend:
  • 22 Answers
Posted on Oct 31, 2014
  • Tissot Master
  • 18,429 Answers
Click this link for instruction for your T TOUCH EXPERT WATCH
http://support.tissot.ch/usersmanual/141-en.pdf
Posted on Jan 29, 2013
Need shell/bezel
Either send to Casio or get new watch. I go with the latter
Sep 22, 2012 | Casio Pathfinder PAG40B-2V wristwatch
I HAVE A LUMINOX 3100 I THINK IT LOOSES TIME IS THIS A SIMPLE FIX?
If any battery operated watch starts losing time or displaying the incorrect time, this is usually indicative of a battery going bad and needing replacement. My Luminox 3100 started lagging in time and I noticed that the second hand would intermittently stop. I also have a Suunto Vector (Digital) wrist-top computer and the times along with the compass, altimeter, light and alarms all started to act crazy and all it happened to be was the battery being run down. Coincidentally the Suunto has a battery gage that only appears and flashes during low battery charge.
BL: Try the simplest thing first, change your battery. Please be very careful not to break the O-ring on any watch that's waterproof/resistant as this will render the protection useless. Also if your watch is still under a manufacturer or vendor's additional warranty, get them to change it as not to void your warranty. 'Hope this helps!
Dec 04, 2010 | Navy Seal Luminox Dive Watch
The screen is swithing between compass - baro -
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Feb 27, 2010 | Casio PAG40B-2V Wrist Watch
Timex exp e tide compas will not work / calibrate
i would advise you to contact timex customer services .
Oct 11, 2017 | Timex Expedition E Tide Temp Compass...
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: [email protected]
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Tissot t-touch t0015204406100
Go to the offical Tissot site www.tissot.ch and download the pdf file "user manual" and there you'll have everything u need to know about operating this great watch...
Jan 12, 2008 | Tissot T-Touch T33759851
Tissot T-Touch : Faulty reading on Thermo, no reading on Altimeter and meteo not working either
If it's under warranty by all means pursue a fix. You might have to send it to a warranty center instead of working with your local dealer.
"Water proof" and "water resistant" are very different. About 20 years ago all watch companies stopped promising waterproof and started using the term water resistant. It gives them wiggle room in the guarantee, unfortunately. I believe T-Touch is supposed to be water resistant to only a few meters.
Nov 21, 2007 | Tissot T-Touch T33159851 Wrist Watch
"Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Feb 12, 2007 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch T33159851 Wrist Watch Logo
5,866 people viewed this question
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you a Tissot Watch Expert? Answer questions, earn points and help others
