Question about Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples
Bt160hl stanly bostitch staple gun how do i load brads
Tina Erwin
    New Friend:
I’m trying to buy brads, where can I buy the brads for this staple/Brad gun?
Posted on Sep 24, 2017
5 Related Answers
Anonymous
SOURCE: Inserting brads into my Stanley
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Posted on Jan 31, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how do I load nails in Stanley powershot staple/brad nails
you can try and go to Stanleytools.com and get to their knowledge base of FAQ or they have a direct way to contact the company for the information you need. I was on their site and have seen better to help the end user.
Posted on Dec 30, 2008
Anonymous
SOURCE: how to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
Good Luck
Peter
Anonymous
  • 195 Answers
SOURCE: Can you help with loading
Look at rear handle bottom, Push in then pull out,load. Please rate. Thanks
Posted on Mar 23, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
How to load brads
My experience is limited with such things.
I have a couple of staple guns that will take brads, unfortunately the brads for one of them are no longer available. The brads had to have a shape and size similar one leg of the staple and a little of the bend at the top so they looked like an upside-down lower-case letter J and it was simply a matter of sliding a strip of brads into one side of the staple magazine.
The other staple gun will accept a more generic sort of brad in the same way but they have to be brads designed for use in that type of staple gun, known as a tacker so they aren't confused with the bigger staple/nail guns. The tacker will generally accept only brads of 20 or 18 gauge.
I suggest you ensure you have the right brads and then just load them like you would the staples.
Mar 28, 2016 | Tools & Hardware - Others
How do I load the stapler?
Search Results
    Stanley electric stapler/brad nailer - YouTube
    ? 5:06
    https://www.youtube.com/watch?v=Zbgt2UXpS-M
    Dec 29, 2013 - Uploaded by Tindlez
    How to load staples and brad nails in Stanley electric staplermodel TREE550 ... Stanley SharpShooter Manual Staple and Brad Gun review ...
    Stanley Electric Staple/Nail Gun (TRE550) - YouTube
    ? 5:04
    https://www.youtube.com/watch?v=6JTZJjQ3wlA
    Jan 5, 2015 - Uploaded by HowToWith GEO
    This video tests the Stanley electric stapler and nail gun. Model TRE550. This video will test both staples and brad type nails. ...Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. Unpack Guy 43,106 ...
    Safety Tips for an Electric Stapler : How to Load Staples into ...
    ? 1:01
    https://www.youtube.com/watch?v=dMsdmYBoojU
    Feb 5, 2008 - Uploaded by expertvillage
    Learn how to load staples into an electric stapler in this free educational video ... Stanley Electric Staple/Nail Gun (TRE550) - Duration: 5:04.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
Can i use 3/4 inch brad nails in my stanley tre500 sharpshooter?
Morning Rhonda,
According to Stanley's own website, the TRE500 will only use either 1/2" or 5/8" brads.
Regards
Alex Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Mar 31, 2015 | Electric Stanley Tre500 Staple Gun /...
WHERE TO FIND A BOSTITCH BT160HL DIAGRAM?
No luck on a parts diagram. Try calling them at this number:
you can call Customer Support at 1-800-556-6696.
Heres the link to the instruction manual.
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=knowledgebase.htm&LEFT=left_knowledgebase.htm
Aug 30, 2014 | Tools & Hardware - Others
HOW TO LOAD BRADS IN STANLEY TRE500
Please download the instruction sheet from the following link which explains how to load the brads. Make sure you have the correct size of brads mentioned at the bottom of the instruction sheet.
TRE500 Sharpshooter Stapler Instruction Manual
Aug 13, 2014 | Electric Stanley Tre500 Staple Gun /...
Stanley stapler/nailer gun spits out more than one staple at a time
Sometimes a gun will double fire, quickly fires twice and is caused by worn trigger valve or safety foot. However, two staples driven with one shot indicates that the staples could be the wrong gauge for the gun or the driver is damaged. The driver of a nailer has a taper on one side of the blade to prevent the driver from hitting two staples. The taper will push the remaining staples back into the rails. Make sure that the taper is facing the staples and that the staples are correct for the gun.
Aug 25, 2011 | Stanley Carrying Case Bostitch Brad...
The gun will fire staples, nails do not set.
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Jan 23, 2010 | Stanley Hand Tools
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
HOW DO I LOAD THE STAPLES IN MY STANLY TRE500
Unplug. Pull out shaft. Flip over. Insert staples into open slot (not on top of shaft).Make sure points are up.
Jul 15, 2009 | Electric Stanley Tre500 Staple Gun /...
Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples Logo
2,006 people viewed this question
Top Stanley Tools & Hardware - Others Experts
JOHN LAPIER
Paul Carew
Joe Garcia
Joe Garcia
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
