Question about Panasonic PT-56TW53 56" Rear Projection Television
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
Posted by Cindy Bolt-Baeza on
    Top Expert:
  • Panasonic Master
  • 76,584 Answers
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Posted on Jan 29, 2013
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Posted on Jun 04, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Posted on Jul 06, 2009
Anonymous
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
STOP THE PRESS!! I FIXED MY TV for a whopping $26.
I took a wild shot and purchased two STK392-110 convergence amplifiers from http://www.electronix.com/. They ship fast, placed my order on Tuesday evening after coming here and placing my comment. To my suprise the parts were in my mailbox on Friday. The parts were actually $12 but I also picked up a iron and a solder sucker.
So rarewish4us, If you're in the South Florida area I'd be more than happy to take that "JUNK" off your hands. LOL
If I were you, I'd give it a shot before you junk it.
Good luck,
Howie
Posted on Feb 09, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: my panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Posted on Sep 11, 2009
Ecollier2012
Edward
  • 3459 Answers
SOURCE: Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Posted on Apr 18, 2010
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic PT-56TW53 56" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
