Patrick Kirkham Posted on Jan 28, 2013
Not printing black
After running the nozzle check and head cleaning several times, the nozzle check pattern shows very few black lines and inconsistent levels of coloured lines.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
279
Points
6
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
5 Related Answers
Anonymous
  • Posted on Mar 29, 2008
SOURCE: Epson 1290 printer
Fix posted yesterday BUT after a few perfect print outs the problem seems to be recurring.... will report back later. Trant
A
Anonymous
  • Posted on Apr 08, 2008
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
Anonymous
  • 353 Answers
  • Posted on Feb 01, 2009
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Gomez
  • 253 Answers
  • Posted on Apr 07, 2009
SOURCE: If the nozzles on my printer are clogged
Most modern printers will "park" the cart. over a small sponge or some other material that will prevent the printhead from clogging, but if it will be "Parked longer than about one Mth." they can clot up.
The printhead on most printers is actually on the cartridge itself, so if you are still having a problem after changing the cartridge.
(I am assuming you are using NEW, not REFILL carts.)
Then I would suggest checking all connections, and as a last resort Uninstall and reinstall the printer software. If all else fails try a printer reset by unplugging the power and press and hold the power button for 30 sec. then plug in and test.
Thanks for the fixya ratings, all I can do is try to succeed in all I can do, is my motto. I hope this helps
Remag1234
Robert Allocca
  • 387 Answers
  • Posted on Jun 26, 2009
SOURCE: my epson cx 6600 black ink not printing.i have
The Black nozzle is Clogged. There are several fixes, too long to write here. Go the website below, they have tools, cleaner, instuctions.
http://www.inkproducts.com/ink-store/
Why is my dell 926 printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Printer is blacking everything out
Hope this helps.
Shane
My printer is blacking everything out
Hope this helps.
Shane
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
2helpful
2answers
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
3helpful
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
New ink cartrage
Note:
    Note:
    Note:
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Printing problems
What does the nozzle check pattern show? Missing lines no doubt. Using compatible inks? I bet you are.
Run the head cleaning routine four or five times then the nozzle check pattern again. If there is improvement keep cleaning it till it is right. If no improvement, check my previous posts about intensive head cleaning.
http://www.fixya.com/support/t138226-printer_not_printing
1helpful
Black ink not printing
You have to run a head cleaning cycle:
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
  2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
    alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper in the sheet feeder.
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
    Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
  6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Printer has completely quit printing color with new ink installed
In order to determine whether this is a hardware or software problem there are several steps you can take:
1.Download and install the most recent printer driver from Epson
2. Try printing out the nozzle check pattern using the Maintenance Utility. This bypasses the printer driver and allows the printer to use all cartridges to print out the patterns. This will indicate whether there are clogged heads and whether or not it will print color at all. Gaps in the patterns indicate clogged heads and you need to run the Head Cleaning utility once or several times.
3. If you get color patterns from the nozzle check (whether or not the patterns are full or have parts missing) you need to check to see if the default settings for the printer have been set to "Black Ink Only". Right click on the printer icon and select "Printing Preferences". Click on the "Advanced" button in the lower right corner and after the popup, look on the left side and see it the "Black Ink Only" box is checked. If so, uncheck it and while you are there uncheck the "High Speed" box as well. This way you don't have to deselect it in the printer dialog each time you print, especially if you are looking for a quality print each time.
4. Try the printer on another computer if you get color during the nozzle check to see if the software is corrupt on your computer.
5. If you get no color patterns at all when doing the nozzle check, it would appear that you have a hardware problem within the printer. It would be unlikely that all the colors would fail at the same time due to severe head clogging.
Hope this helps in some way.
k24674
ADMIN Andrew
ADMIN Andrew
