Question about Fisher and Paykel GWL11 Top Load Washer
Where is the pump on my Fisher&Pakel GWL 11 AND HOW CAN I GET IT OFF TO CLEAN IT
Where is the pump on this machine; can it be removed to unclog it ...
Posted by Donna Farrell on
Greg Stephen
  • Fisher and P... Expert
  • 566 Answers
Tilt your machine back on a 45deg, look up under machine to find pump
pull back on the white lever & turn anti clockwise to remove.
Posted on Feb 11, 2013
  • Greg Stephen
    Greg Stephen Feb 11, 2013
    Don't forget to turn off power & disconect from the wall.
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: GWL-11 Fisher Paykel wont turn on and water on the floor
Look at my issue "eco smart won't drain, smells hot". Mine is top load.
If you see puddle on floor and eventually won't run at all and smell electric burn motor, it could be same issue I had.
Unplug washer. Tip washer back. If you see water dripping through the black motor area, you need to remove the black motor and the white plastic unit above it. Look for a white plastic clip that is attached to bottom of washing machine. Push that clip with your finger and twist the whole plastic unit/black motor. It all comes off in one piece.
Look on side of this unit and you will see 120V or 240V. Mine is GWL10US and is older model. Was told by repairman that new units use 120V. That is what you need to order. It comes as one piece and you just twist it back on. I had done most of this. Repairman came and 5 seconds cost me $65.
Posted on Oct 20, 2008
Anonymous
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Posted on Apr 06, 2009
Anonymous
  • 145 Answers
SOURCE: 4 year old Fisher Pakel washing machine
Hi and welcome to FixYa!
Some things to check- Start with the water pump underneath the machine in the right-front of the unit. Look for signs of rust or leakage, that would be the most likely cause. Also check the operation of the diverter valve, inspect it to make sure there is not something like a lint ball or small object caught in the flapper; this can allow water to seep out of the diverter when it is supposed to be sealed in the spin or drain cycles and this seepage will get on the tub's rim as it spins and cause a leak on the floor. This kind of leak will cause water to appear as if it is leaking between the top and the cabinet.
Word of caution- the water pump is electric, and if you allow this leaking to continue, it can actually short out boh the water pump as well as the machine control.
If afer you solve the issue, if you find that I have accurately described the problem, a FIXYA rating is greatly appreciated. Thanks!
Posted on Feb 15, 2009
Anonymous
  • 3 Answers
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Posted on Oct 09, 2009
Anonymous
  • 67 Answers
SOURCE: During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Posted on Apr 18, 2010
Testimonial: "My pump is definitely the source of the burning smell. Thanks for the quick reply."
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
WAS THERE A RECALL ON FISHER & PAYKEL GWL 11
no not thst i know of but its always been a problem with them over tha last 20 years
How to get to pump gwl 11
The pump is at the bottom of the machine, remove the bottom front inspection plate held in by 4 plastic screws, remove the plug from the wall and with a torch you should be able to see the belt and the pump. To test the pump remove the belt and turn by hand, if cannot do, you have a jammed pump and possibly a cooked electronics board. You can easily examine the pump.
2helpful
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
3helpful
2answers
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Ekse
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
