Question about Lexar JumpDrive S73 - USB flash drive - 16 GB
Can't download a 10 gb movie into 32gb lexar s73 jumpdrive. it says it's full
william_hleu
    New Friend:
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Posted on Jan 30, 2013
3 Related Answers
Anonymous
  • 148 Answers
SOURCE: Lexar Jumpdrive Secure II problem
the directory is corrupted.
when your computer accesses the drive, it knows some things, like how big it was.
but it does not know where the data is.
it does not see anything that tells it what is on the drive, thus the empty window.
not a serviceable unit if the mfg will not give you a fix it program.
sorry for the news.
mark
Posted on Dec 23, 2007
Anonymous
  • 101 Answers
SOURCE: lexar jumpdrive
its simple ( i dnot have a mac)
go to applications and select Disk Utility and select ERASE !!
that would do the job dear !!
Posted on Mar 09, 2008
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Posted on Aug 14, 2012
I want to transfer music from one computer to another using Lexar jumpdrive s5032 gb. How to do that
Upload the files to the jumpdrive. Remove jumpdrive from computer 1 and insert in computer 2. When computer 2 recognizes the jumpdrive, copy the files to a directory folder where you want to save the music. Unplug the jumpdrive.
May 13, 2015 | Lexar JumpDrive S50 32 GB USB Flash Drive...
I want to add more pictures to my lexar jumpdrive S50, 16gb
Change the formar type to ext2 or ntfs if tour problems are file size related. If IT es because thw pen es full you will hace to deleite unwanted files.
Aug 11, 2014 | Lexar Jumpdrive S50 16 Gb Usb 2.0 Flash...
Cannot format s73 jumpdrive
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Dec 22, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
USB flash devices don't need drivers. I believe you might have removed one or both of these drives from the PC without using the proper procedure, and the PC (or notebook) is now "confused". Re-attach one or both devices, but this time, either use (Windows) Explorer to "electronicaly" eject the device (right click, then choose eject) or use "Safely Remove Device" shortcut, usually on the bottom right=hand corner of your screen (the taskbar).
Sep 11, 2017 | Lexar Media Jumpdrive S73 - Usb Flash...
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
Jumpdrive states full but is not
File system error - format it the slow way in a different system.
Jun 15, 2010 | Lexar JumpDrive Classic Portable USB Data...
Lexar Jumpdrive Data Recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jun 05, 2008 | Lexar JumpDrive MP3 Player
Lexar JumpDrive S73 - USB flash drive - 16 GB Logo
96 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Harrie
john smith
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
