I have aHitachi 42" lcd that went blank.Now the red standby light which turns blue when on are now flashing together the set is only 18 mths old
Posted by robert fice on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,312 Answers
This is symptomatic of power supply failure even though, as you say, the TV is only 18 months old
Posted on Jan 28, 2013
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
coyotedave
  • 280 Answers
SOURCE: HARWA LC37W18S LCD TV using KAS200-5S241812XLS
Check all the caps on PSB. if any look puffed , replace them. If you are getting 14volts to the ivnerter board PS is good and the inverter is bad.. good luck
Posted on Apr 10, 2009
Anonymous
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Dec 19, 2017 | LG Televison & Video
My 47LG70 tv went out. I heard a pop and the screen went blank. The lower right hand sensor light turned blue. I tried unplugging but that didn't work. When I tried to turn it on again the sensor light...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | LG 47LG70 42 in. LCD TV
My standby light flashes red/blue? and no pic,its only weeks old
I would take it back and get a replacement, it is a lemon, it will void warranty if you open it up. It can be defctive power supply module.
Dec 09, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Philips Tv won't power on.......
Try plugging in the USB drive and HOPE that the P.O.S.T. during that 2 second period grabs the upgrade, but I must tell you that this is a hail-mary pass.
After that, it's DOAville!!
Mar 29, 2009 | Philips 42PFL5332D 42 in. LCD Television
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
[email protected]
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
