Question about Bryant 3.5 Ton R22 12 Seer Condenser Only/ Unit has an R22 Charge
Have a bryant 3.5 ton outside can I change to a bryant 4.0 ton and still use the same inside equipment
Posted by txkyfl1 on
Todd B
    Master:
  • 572 Answers
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier. Hope this helps.
Posted on Dec 06, 2013
  • Todd B Dec 06, 2013
    Your inside unit can be up to 1/2 ton larger than your outdoor unit, but NOT the other way around.
1 Related Answer
Anonymous
  • 246 Answers
SOURCE: The inside unit on my
I would think that when you changed the fuses you 'cured' the problem - which was a blown fuse(s) - but now you have the same problem again - a bad fuse(s).
To test this - you could replace the fuses again - but first - I would make sure that the fuses you are using are 'time-delay' fuses. It should say on the fuse itself 'time-delay' or 'dual-delay' or something like that.
If you're using fuses that are not 'time-delay' your problem could be solved as easy as buying some 'time-delay' fuses.
However, -- fuses blowing -- are usually caused by electrical motors - i.e. compressor/fan motors - breaking down 'electrically' - and heating up and causing the amp draw to increase past the point of the fuses, i.e. a 40 amp fuse will blow when the AC starts to exceeds that rating.
One "longshot possibility" - is - if the condenser is 'really dirty' - it will cause the compressor to run hot and possibly cause the fuses to blow. I would make sure 'all power' including the inside thermostat is "off" - and then 'wash out' the condenser (the coil in the outside unit) real good with a water hose.
Of course another possibility is that you have a loose electrical connection(s) somewhere in the AC. If you're inclined to - you can again - make sure all power is off - and poke around in your AC looking for loose wire connections. Just be sure 'all power' is off before you do this.
If you are using 'time-delay' fuses and your condenser is 'clean' and you can't find any 'loose connections' - and you continue to have the same problem (blowing fuses) - I would suggest calling a Service Tech.
Note: never replace a fuse with a bigger fuse, i.e. if the fuses in your unit are 40 amp - 'do not' put in 50 amps.
It is possible that the fuse(s) you are using are not the 'right size' but that would have to be determined by a Service Tech and actually - is not a strong possibility, although certaintly possible.
hope this helps
Posted on Aug 14, 2010
What is the model# of a 3 ton bryant package unit and the ARI#
Somewhere on the equipment is your model #. Unless it is old and has faded off, it should have your model #. If this has happened, sometimes you can remove a panel and find it on the inside. The AHRI # as it has been called since 2007 would be dependent on this number.
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
2answers
Will goodman outdoor ac work with bryant indoor unit
My three ton bryant model 597a outside condenser will start and run for about 30 seconds and then shut off. 3 minutes later it will do the same thing. Both the condensor motor and fan start. Help please.
going out on safety sounds like a time delay relay holding it off for 3 minutes to prevent a short cycle. i.e. someone playing with stat power failure etc.
I am trying to replace my old bryant heat pump with a new bryant heat pump, but I am having a difficult time figuring out the tonage. Can you tell me if I have the model number?
yes just post the model number and someone will be glad to help you..
fyi if the model number has for example 373036 373042 373048
the o and number after it usually is the btu value...
12000 btu's = 1 ton so a 036 would be a 3 ton 042 3 1/2 060 would be a 5 ton
post the number someone will help you out... another way to find out
carrier which makes bryant units can help you also
a number for ft. worth location is 817-834-4496 good luck to you
Open Questions:
0answers
Why won't my Reddy Heater R55 run with the upper shell on? My Reddy Heater R55 will not run properly with the upper shell installed. Initially, the unit wasn't sparking, so I replaced the transformer ignition control and installed a new spark plug. That fixed the sparking issue. However, this new shutoff issue was discovered. I elected to replace the lint filter, intake filter, and output filter, as those pieces all looked pretty old. The filter end cover was cracked on the side and spitting out air, which I replaced. After the same issue continued and the unit shut off after a few minutes with the upper shell on, I replaced several other things. This included the photocell, nozzle and adapter, the adjusting screw, spring, steel ball, and the 1/8" ID air and fuel lines. After digging deeper into this, I noted the old 3/16" ID air line was leaking with a bit of soapy water, my dad's best trick for finding leaks. One thing to note, when I have the upper shell off, I have set the pressure to 3.4 PSI (per the side label), but when I put the upper shell on, the PSI drops to below 3.0 unless I hold the gauge still. When I hold it, the gauge reads 3.4 PSI. A couple of final things to note on this journey. 1) The fuel cap does not look to have a gasket but it seems to breathe properly with the hole in the center of the cap. 2) Before any issues started, I was running pump kerosene. Since then, I filled up with 10 gallons of jet fuel at a local airport and wondered if I got bad fuel from them. I plan to run through the last 7 gallons or so of jet fuel with the upper shell off and then try a couple of gallons of pump kerosene to see if that resolves the problem. Beyond all of my attempts, I am at a loss and could use some help. I've spent more on these repairs than the unit is worth but started the process in hopes of fixing the heater, as my wife's grandfather gave it to me a couple of years ago. In hindsight, I should have just bought a new unit, but here I am.
See all Bryant 3.5 Ton R22 12 Seer Condenser Only/ Unit Questions
Bryant 3.5 Ton R22 12 Seer Condenser Only/ Unit has an R22 Charge Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
