Philips 60PW9363 60" Rear Projection Television Logo
Mark Mccabe Posted on Jan 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phillips 60 inch rear projection tv is stuck in the cvi mode and i can't access any other modes
It wont let me move through the other modes such as hdmi etc
Anonymous
Level 3:
  • Philips Master 3,459 Answers
  • Posted on Apr 19, 2013
Anonymous
Philips Master
Level 3:
Answers
3459
Questions
5
Helped
849121
Points
5558
Get a service manual...it should show how to reset the tV
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 14, 2007
SOURCE: Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Anonymous
  • 3459 Answers
  • Posted on Apr 11, 2009
SOURCE: Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 25, 2009
SOURCE: Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
maatmartin7
matt martin
  • 1259 Answers
  • Posted on Aug 27, 2009
SOURCE: I have a 60 inch phillips rear-projection tv and
This TV needs the small signal board replaced. It is a 3X5inch video card. Call Anrews Electronics at 1 800 648 6657. Have the brand of your tv and its model #..Tell them you are looking for the SSB. Should be about a thousand of these and they will ask to return the old board. About $275 and you should get a dud return fee of $50. Pay close attention to the accompanying instructions. The Geometry set up is necessary to fill the screen of the tv. And good luck.
Anonymous
  • 3459 Answers
  • Posted on Dec 22, 2010
SOURCE: Yes my 60 in phillips
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Stuck in video1 and video 6 mode. Can't get to tv
ok, all sony sets for the last 20 years or so have had a reset feature that ought to clear this up:
Set turned off and using Sony original remote:
Display, 5, volume up, power-----listen carefully this should take you to the tech menu.
hit 8 and reset should appear on the screen in red
hit enter and the reset should turn to green and set shut off.
Turn back on and see if it cured the issue or not.
HAVE PHILLIPS 60 INCH 5 YRS OLD GREAT PICTURE NO
Hi, check for any speaker switches around rear of set that may have been accidentally switched. Could potentially have a "hotel lock mode"
which some philips sets automatically entered after a set time (namely months) which limited volume settings. Your friendly local service technician may be able to help you out with that one
I have a 60 inch Philips HDTV, it looks like we are watching all channels in 3d mode. is this something that i can easily fix?
Yes you can get the Phillips DPTV305 - DPTV345 convergence repair kit at www.tvrepairworld.com the kit contains the parts and the CD with instructions.
1helpful
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Digital Convergence Mode
Jou must hold in the menu button wille putting set on and press the code wile hulding in the menu button on tv.
2answers
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
