Question about Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White
What do beeps mean on frigidaire washer dryer controls
I have a Frigidaire electric dryer it won't start and beeps three times I'm not sure what year and make
Good Afternoon Frankie, thank you for your inquiry!
Based off what you have described your Frigidaire dryer is not starting and will only beep three times. This could be a possible issue with your control panel or sensor. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. You may also want to check your household circuit and assure that the breaker did not flip or that the circuit has not shorted. If that all appears to be in proper working order then I would suggest consulting with a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
The dryer work but not the washer
Does it turn on at all? Any lights or beeps? You might want a professional to look at replacing the main control board if everything else checks out okay.
We are getting a Err 68 but he dryer heats up and turns. The only thing is it keeps beeping
this means there is a stuck button on the control panel try find the one that is stuck and free it up.if there is no button stuck then you may need to replace the control board.
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
6helpful
Dryer says locked
The Operating Instructions say this:
Control Lock
To avoid having someone accidentally start or stop
the washer, press OPTIONS and Select at the same
time and hold for about 10 seconds until the
(Control Lock) lights up. “LOC” will be displayed
alternately with the estimated cycle time. Turning
the Cycle Selector knob or pressing any button
will produce flashing indicator lights and/or beeping.
To unlock the controls, press and hold OPTIONS
and Select for about 10 seconds.
Dryer beeps when it isn't running
sounds like the control board, is there any codes displayed?
Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
