Question about JUMP START SYSTEM
Do you have CB 19/12 replacement battery - JUMP START SYSTEM
Why does my CB only have black and red wires what are they to?
The red wire is your positive wire and the black wire is the negative wire. This hooks up to a car battery or a power supply to turn the radio on.
Sep 06, 2014 | Green Planet Kraco Kp6001h Replacement...
How to re-wire the flashlight Makita BML185
You have a battery a globe and a switch. It really only matters matter if you keep the circuit board(CB). Here's how mine was wired.
Red - Battery pos to switch to bottom of CB (BT+)
Red - top of CB (BU+) to pos contact pivot
Black - neg contact pivot to top of CB (BU-)
Black - bottom to CB (BT-) to battery neg
Or you could just bypass the CB altogether, wire the black to the black, and the red to the red. done.
Jul 31, 2012 | Makita 18V Lxt Lithium Ion Rechargeable...
I own a 2007 Goldwing with approx. 8000 miles on it. After the battery went dead (and rolled the bike down an incline to jumpstart it), I began to experience problems with my cb and radio. The cb will...
Did you replace the battery or charge it back to capacity?
If your battery is not at full charge or isn't supplying the correct amps to the electrical system, every time you key your CB it will drop the voltage and other electrical components will stop working - or not work properly.
Make sure that your battery is fully charged and the electrolytes are at the proper levels.
If you put a new battery in your Gold Wing, did you buy the correct battery? A cheaper battery will most like cause problems with the electrical system.
If you find this information useful, please vote on this post. Thank You.
Regards,
Oz
Jan 12, 2011 | Honda GL 1800 Gold Wing Motorcycles
I've got a Midland Model-1000 CB connected to a Firestick II 3ft antenna. I can hear people loud and clear AND almost pegging the meter. I've tried to get a MIC check and I get no reply, believing the...
Could be your mic.. is it an amplified mic that has a battery in it? or a non... try replacing the mic or if it has a battery in it you probably have a dead battery that needs to be replaced..
Apr 16, 2010 | Midland 1001Z 40-Channels Base CB Radio
Not able to finish transmiting.
1 check and clean mic switch
2 check and repair wires in mic plug
3 if preamp mic replace battery
Jul 03, 2009 | Radio Shack TRC-503 CB Radio
My Cobra Road Trip handheld CB won't switch over to battery power when I unplug the 12v adapter. How do I open the casing to check if the spring behind the connector can be repaired or replaced?
Make sure you have good batteries in it ,and installed correct. There should be a switch behind the battery,i think.... but there is a switch on it for ac or dc,switch it to dc,make sure you have the ac plug adapter end unpluged from it in order for it to work......hope this helps.....
Jun 28, 2009 | Cobra HH 38 WX ST CB Radio
Blowing fuses with wiring CB to battery
Is the wire going to the battery touching chasis ground at all? Accidentally pinched it, cut wire etc? If not the the power supply may be fried.
Jun 04, 2009 | Cobra 29 LTD CB Radio
JUMP START SYSTEM Logo
52 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
