Can't get the sensor to shut off
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
SOURCE: I have a single pole
Unless I misunderstand you, you just need to get a single switch, and a duplex outlet with a matching plate. Your hardest part will be to decide the color of the devices and plate (rectangular, double-D holes, etc. I'd suggest, that for "preserving domestic tranquility" you hire you mate (if any) as consultant on these matters.
(Wire it as it is now; that is if the switch controls the outlet the wiring should still be easy to follow.
DO turn off the power first!)
SOURCE: replacing a single pole switch
The old single pole switch has 2 black wires.
One black wire is hot from circuit breaker box, and the other black wire goes to load (light, fan, motor)
New device has black wire: connect this to hot from circuit breaker box.
New device red wire: connect this to load wire
New device has white wire: connect this to Neutral wires.
Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box. If your box does not have neutral wires, then connect device white wire to bare ground wire.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: Single Pole Illuminated switch doesn't
there should be two wires coming from switch both black you should hook up the hot wire to one the other to the light it self. if there hooked up right then the switch would be bad if you have a volt tester this will tell if you have a hot wire or not , good luck
