Question about LG Televison & Video
My pc is connected to my tv using an hdmi cord, it frequently cuts out and says no signal
I have a HP pro-book 4530, I have tried 3 different hdmi cables thinking the cable was not fast enough or just not good enough. I usually just watch netflix from my laptop to my tv, but a few minutes into an episode the tv will turn black and say no signal, the show will continue playing on my laptop...
Posted by A. W. on
Tony Ray
    New Friend:
  • 17 Answers
Sounds like either the laptop's hdmi output, or the tv's hdmi input is the problem. You can findout wich one by connecting the laptop to another set and see if it still happens. If it goes away then it is your tv input, if it is still there it is the computer.
Posted on Jan 28, 2013
3 Related Answers
rapanSF
Ken Kichi
  • 150 Answers
SOURCE: TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Posted on Dec 03, 2008
jimnuggats
  • 644 Answers
SOURCE: I am attempting to connect
Adjust the computer resolution to 800-600 and set the lowest bit rate, ie not 32bit. 24bit or 16bit will be fine.
To do this right click on the screen and choose properties, click on settings and you will see the slider bar the resolution and the drop down menu for the bit rate.
The reason you have to do this is because even though its a tv it works on a lower resolution than a computer monitor and is unable to show higher res.
Posted on Aug 21, 2010
David Bukovaz
  • 144 Answers
SOURCE: HDMI signal turns on and
If you have more than one HDMI connection, have you tried using a different connection? Also, if you have another T.V. with HDMI, try connecting the device to the other T.V. and see if it works. Right now it could either be your T.V. or your device you're trying to hook up. If the device works on another T.V. then it's the T.V. that's bad, if it doesn't then it's probably the device that is bad.
Posted on May 04, 2011
There is no signal on my emerson tv, how do i get one
1. You are not on the right input for the signaling device: Verify which input number (or type ie HDMI/component/video/Cable) your device is connecting to and tune to that input.
2. The signaling device is not powered on. Verify it is on and the cable is properly seated into device and TV.
3. The cable is bad. Try a different cable or use alternate type of connection.
4. The specific input port on the TV is bad. Move the connecting cable to a different port (ie from HDMI 1 to HDMI 2) and tune the TV to that input.
If you are using an Over the Air signal (OTA) with rabbit ears or and antenna use the TV menu to run an auto tuning scan of your local stations.
If you are using a tuning box (cable/satellite) over a coaxial connection check connections and tune the TV to CH 3 or CH 4 and check for picture. There may be a switch on the back of the box indicating CH 3 or CH 4.
Sep 18, 2017 | Emerson Televison & Video
Hdmi ports om our lg tv are not working
yes you have to replace the mainboard just buy the part yourself and install it there's not much to it buy the part @ www.shopjimmy.com
Mar 02, 2013 | LG 47LW6500 47 3D LCD TV
I am attempting to connect a PC and/or a Playstation 3 via an HDMI cable and my Samsung Plasma Model HP-5033 will not read the signal between the PC and television. It reads a "No Signal Detected" message...
Aug 21, 2010 | Televison & Video
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
Tv says "no signal" when i turn on PS3
About holding the reset button, I assume you know how to use that trick, you might be missing something, though: Probably you have your TV set to the incorrect input, eg. Connect only the HDMI, set your TV to HDMI input and go with the power button trick (press (youll hear a beep), dont release until you hear a second beep) the system will autmatically display through HDMI, it can take up to 5 secons or so.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
TV SAYS "UNKNOWN SIGNAL" AND I CANT GET ANY VIDEO OR AUDIO
The cord may have a short in the wiring. A pin in the connector could be missing. Or the PS3 hdmi socket could be bad. You should call Playstation Technical Support line at 1-800-345-7669 (1-800-345-SONY). If it under warranty you should not try to fix this problem yourself as you could cause even more perment problems.
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
PC to TV can't seem to get to work.
okay buddy its esay just give me a good rate!
u select:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Feb 06, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Connecting laptop to sony hdmi tv
There is a option on T.V.'s that you need to put it to VGA on the t.v. also you can go into properties on the output of the video to the t.v. and laptop to verify that it is sending a signal.
Also check to make sure all the cords are pressed in properly and that the cord doesn't have any cuts or cracks in it or any pins are bent at one or another end it happens sometimes it get's plugged in the pins aren't hard to bend.
Happy Holidays
Dec 18, 2008 | HP Pavilion dv1000 Notebook
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Televison & Video Logo
348 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
