Pioneer DEH-P80MP CD Player Logo
Question about Pioneer DEH-P80MP CD Player
IC POWER DAMAGE
I WAS TRYING TO CONNECT WORES AT THE BACK OF THE SYSTEM WHEN TWO TOUCHED THERE WAS A TEMP LOSS OF SOUND. tHE SOUND CAME BACK BUT ON THE DIPLAY THERE IS A MESSGE THAT SAYS "IC POWER DAMAGE"!! THE SOUND WORKS FINE AND DEMO ON THE SCREEN EVEN COMES UP. HOWEVER I CANOT ACCESS THE MENU TO ADJUST BALANACE FADAR ETC BECAUSE WHEN I TRY THIS THE DISPLAY JUST DISPLAYS IC POWER DAMAGE. I AM STUCK ON WHAT TO DO AS THE SOUNS STILL COME OUT AND DEMO DISPALY WORKS WHEN NOT IN OPERATION. PLEASE HELP ME SOME ONE
Posted by roisul abedin on
  • roisul abedin Jul 31, 2007
    hello
    thanks for the advise but i cannot find this reset button. what does it look like??
    I already have taken the systen out the car and plugged back in and it still shows this message
Anonymous
    New Friend:
  • 83 Answers
Take the unit off the wiring harness and hold unit in your hand , find the reset and push the reset button for 7-10 seconds....afterwards plug in the harness and turn on the unit...and it should work as new...i hope this helps...i have the same unit
Posted on Jul 30, 2007
Anonymous
Take the cdplayer and hoopit
Posted on Dec 09, 2007
Insignia receiver powers up then immediately shuts down
Sounds like the wires touching shorted out one of the amp ic's. Would have to get that ic replaced before it will power up again.
Hello, I have NEC MultiSync LCD195VXM+ and when I turn it ON, there is just white shining LCD and nothing else. When plugged in power it came shining ON and after about five seconds its go into sleep...
1. From what you have described this sound as though the video card ( internal) is defective. Most mother boards have video cards on the mother board.
2. use a know good video card and install it to the mother board > there should be ample slots to install it.
3. The OS (operating system should see the installed video card immediately and install drivers if you see a screen then this has isolated the problem to video.
If you don't see any video then you have a defective mother board.
My sony KV-G21PD1 sounds are not working
Hello
Either your TVs internal speaker or its sound output Ic has damaged. You can make sure about which part is damaged through the following sugession.
Just place your ear, very close to the TVs speaker side, and switch on your TV with its front panel power switch, not by the remote control. If you can hear a 'thumb' sound or 'HUM' sound, you can make sure that the speaker is ok. If you hear a 'HUM' sound as describe above, make sure that its sound output Ic has damaged. If the sound output Ic has damaged, sometimes you may not hear any sound at all too.
Connect the TVs audio out RCA scoet to an amplifier, if you have, and try to get the sound through it. If there is sound through an external device, make sure once again that the internal sound output Ic has damaged. Speaker can be checked by a torch cell, connecting its terminals to the two leads of the speaker, with two pieces of wire, just intermittent touch, you can make sure that it is ok or not.
To replace the sound output Ic, you must open your TV, and locate the sound output section inside it. It is easy, to do, just follow the speaker wire, and find it from which point from the main board it orginates. Somewhere near to it, you can loact this Ic.
Before replacing the Ic, just measure whethere there is voltage comes to its supply terminal or not. If there is voltage, and no sound at all, replace the Ic with same type and number without any doubt.
If there is no voltage comes to the input pin of that Ic, check the track leading voltage to that point, and find whether there is any resistor has opend or not. Ok
If you need any further assistance, contact me through Fixya.
OK.
No picture just get a white screen. Can it be reset somehow?
Hello
You haven't mentioned, whether there is sound is Ok or not. Anyway, according to your description I understand that there is no sound too. Assuming this I advice you to replace its tuner. If there is only a white screen, that is a raster only with no grains, tuner or chroma Ic may in trouble. In your case it may be chroma Ic itself. If chroma ic fails there will be no grains. In most of the modern TVs One Chip Micom is used. That 90% of tha sections are integrated to one Ic. Video If, Chroma, vertical and Horizontal Oscilator, sync: circuits, System Control etc. If any of these section inside the said ic fails, replacement of that Ic is the only remedy. You just check the chroma Ic first. If it is fauty, it will heat up more, such that we can't touch it. It will be heated upto 50 to 65 degreeC during operation. But not more. To check this, open the back cover of the Tv, locate the said Ic [it will be larger in size normaly have more than 50pins of connections on both sides; say it as DIL type, means Dual In Line], switch on the tv; without touching its any internal parts, wait for two or three minutes, switch off the set and plug out the mains chord from wall socket; and just touch it with your bare fingers and feel the heat effect. If it is too hot that you can't touch it; it is the faulty. Be caucious during this process. Never touch it with power supply is energised. Keep the power plug out from the socket, before doing anything inside the Tv and keep the children away from you.
2answers
Runs fine till warms up then losses power and dies
Does the fuel line still have 55 PSI when engine warmed up? Any other codes show up?
My tv goes off by itself, after a while it comes back on. two days ago it went off and i cant get it back on
There is an IC in the TV that controls all functions; power on\off, volume, menu functions, etc.
When this IC losses power it will turn off the TV.
When this IC regains power it will restore the TV to the last Known condtion before the power was lost (OFF or ON)
It is possible that this IC is defective and has intermmitant power or functionality. This would result in this intermittant off and on and why you cannot power it on suddenly.
Also, be aware if the outlet that the TV is connected to losses power you could get this symptom (same if the outlet has a loose connection with the TV power cord)
overall point is:
1. Ensure the wall outlet is in good condition and the TV
2. the TV power supply could have some issue
3. if not 1 and 2, the TVs main board may be defective.
2answers
Loss of sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
3answers
DURABRAND HT 3916 Surround Sound System - Fuses keep blowing immediately!!!!!
i exactly dont know whats wrong but if its humming, then its not the problem with any of the fuses.
My E330 in water,the touch screen cannot align,how enterinto the system?
The IC(integrated CIrcuit inside your phone is damage since it getting wet.the IC that connect your touch screen and and the main processor is damage,the only way is to change the iC quick possible you can sent to their service center and ask them for tecnical support.i your warranty still not expire,i think they can fix for you..Feel free to ask for their support:)
No sound at all in any mode
If you get a F61 error when the unit is powered on then the output ic is bad.Subwoofer has the power amp built into it.You may have damaged the IC with a mixup in the +/- speaker hookup and the common ground connection in the A/B box.Seems your subwoofer will need service.
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
